How would you improve your tractor?
/ How would you improve your tractor? #1
Jaylegger
Massey Ferguson GC2600L
Curious what aspects of your tractor owners feel the manufacturer should alter to make your tractor better. After putting only about 60 hours on my GC2600 a couple annoyance corrections come to mind.
1- In low-range I'd prefer reverse to have the same gearing as forward, I understand in high gear this may cause stability issues but low reverse is painfully slow.
2- The method of locking the mower lift arms in the up position could be refined. Instead of rotating the height adjustment knob to it's highest position which imo is a bit of a pain, a simple lever type mechanism would be great.
3- Perhaps it's there's an adjustment somewhere other than the spring but the 3 pt hitch lever won't stay down in the float position. A more precise and effective tension system would be appreciated
4- The tail lamps on the ROPS should be designed so they can folded in-ward of the bar to prevent snagging of trees and such while operating in close quarters.
5- The mid pto should come with a cover. The manual states to keep the pto's covered when not in use (the rear comes with a cover) but the center shaft has none nor is one available.
6- A variable rate lever for raising the 3 pt arms. (Thanks Wacky, I forgot about that one)
/ How would you improve your tractor? #2
1 Wheel spacers.
2 For some reason when using my 3pt lift I have grabbed the gear selector and shifted into neutral instead of lowering the 3pt. Maybe a little lock-notch in the fender to prevent this?
3 A way to adjust raising 3pt slower.
4 A stationary valve to attach BH hoses to on the tractor, rather than the hoses dangling back there.
/ How would you improve your tractor? #3
On mine a good operator would make a world of difference!:thumbsup:
/ How would you improve your tractor? #5
You Massey boys aren't alone, of course. I might begin with:
- improving the 3 pt arms and check turnbuckles on the BX.
- give it a better hour meter and readable tach.
- might even offer true position control on the 3 pt.
- a less rpm oriented engine.
- lose the HST fan system
- reduce the HST whine
- change to a one piece, easy lift hood.
/ How would you improve your tractor? #6
Just location for 3pt lever on L2800HST..to close to leg.
/ How would you improve your tractor? #7
Some kind of cab before next winter! Then a heater! Hey, maybe a radio. It never ends!-
/ How would you improve your tractor? #9
A brake set that locks both pedals individually, a solenoid operated multi spool selector on 1 remote, a park gear, belly plate for soft underside and to provide a storage/carry area, a creeper gear, more lead on front drive ratio, more aggressive governor, cast rear wheel hubs, valve stem protectors, override to enable start while in gear, loader lighting provided by LEDs on loader arms and bucket rim, front diff lock, more lift range on 3ph, more bucket curl, stronger power steering, all loader parts made using high strength steels and good engineering to provide good strength to weight, telescoping 3ph lift arms that will lock in various extended positions ... etc
larry
/ How would you improve your tractor? #12
I'd add a tool box, cup holder, working hour meter, place to hold some chains, hydraulic top link and tilt, 3 point down pressure, wider stance, etc. I recently was wanting a workbench to mount my vice on and figured it would fit on my tractor. It bolts onto my brush guard and clears the hood barely went mounted forward. I can also turn it to the side. I've already used it to fix small things. Since it is held on with 1 bolt, i can easily remove it before i got out working in the woods.
/ How would you improve your tractor? #13
I can only think of 2 things.
1-For my land, in mid-range 4th is to fast, 3rd painfully slow
2-The shuddle shift wires under the tractor are not protected. When clearing land I am always think I am going to get them ripped out.
/ How would you improve your tractor? #14
A better system for stowing the BH hoses when using the three point hitch.
With 58 hrs on it you can see signs that the hoses have been dragging on the
three point arms. Two bungee cords and a prayer every time I change over now.
/ How would you improve your tractor? #15
A tractor that can transform to whatever I need at the time.:D I'd like to have a bigger hour meter on my Kioti. Already gots a cup holder- I thinks it needs to be a cooler. That's it-a space to mount the cooler.:D:licking:Standard Pats easy change, top n tilt, lights on loader and rops. Toolbox for chains.
/ How would you improve your tractor? #16
Adjustable steering wheel
/ How would you improve your tractor? #17
4-Thats one reason to go with the widest MMM you can get.
Keeps tractor farther away from things such as trees walls ditches and banks resulting in less damage danger & back breaking trimmer use.
2*This can be a disastrous error on a BX going up or down hill.
Very scary!
Well of course:thumbsup:
A good operator can have many different conotations.:D
This can be very hard to find :drool:
/ How would you improve your tractor? #19
Very scary!
That's when it first happened going down backwards, tried to lower the BB and :shocked:!!!!! Right into neutral she went, smooth as glass.
I need to figure out how to avoid this. Quickly!!!
/ How would you improve your tractor? #20
+ 1 :thumbsup:
Kiefer Built Livestock Trailer (A66285)
Kiefer Built...
2000 SHOP TANDEM AXLE TRANSPORT TRAILER (A65643)
2000 SHOP TANDEM...
Terramite T9 Backhoe (A65579)
Terramite T9...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
Man Basket (A65640)
Man Basket (A65640)
