SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,557
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Also, and maybe I am wrong here, but I don't think there is much turbo lag on a tractor, afterall you rev the throttle to a paticular RPM, and it stays there. The exhaust pressure is the same while you are driving or not. Might be a slight delay if you hammer the throttle and then the go pedal, but after that it should be constant power.
The key issue regarding lower lag on a diesel is the intake is always wide open. The engine is sucking as much air as it will and all that comes out at increased volume driving the turbo. When idling, slow or fast, there is not much fuel being burned and so theres not a lot of volume increase between intake and exhaust. This is a low boost condition -- the turbo is running slow. Still, its alot faster than one on an idling gas engine because that one is sucking on a closed throttle plate. The one in the diesel has a head start so to speak. It starts at a higher speed and so spins up quick when more fuel starts being injected to make the power needed to drive a load. It bootstraps itself effectively ... more fuel - more exhaust - more turbo speed - more boost - more intake - more exhaust.... This takes the engine quickly from a too rich condition in the initial response to a sudden load to the lean condition normal for diesels that are running below their HP rating. There is a brief puff of black smoke during the time it takes for the turbo to spin up.As far as turbo lag, that's mainly a gas engine problem due to the fact gas engines have a much wider rpm range. I had a toyota with a turbo that red lined at 8,000 rpm. A correctly designed turbo will need to provide the correct CFM. An engine turning high RPM requires a lot of air and a bigger turbo. The exhaust flow at low RPMs is just not powerful enough produce any boost. Some manufactorers have been installing two turbos on gas engines, a small turbo to provide boost at near idle engine speeds and a main turbo to provide the CFM needed at higher RPMs.
larry
