Buying Advice What older model Fords would you look for (40-80hp)?
   / What older model Fords would you look for (40-80hp)?
If you have any suggestions for barns I'd love to hear them, too. I can't believe how much they want for what seems like not very sturdy buildings around here. I've almost decided just to put up a simple steel truss without sides to keep the cost down and finish it later if I decide, too. What does your metal building look like?
   / What older model Fords would you look for (40-80hp)? #32
   / What older model Fords would you look for (40-80hp)? #33
That is nice. Ours will be right by the house and if we go metal I think I will go with the vertical look for the roof with eves to match better.
I need a work shop and coverage. Carolina Carports have a tall building with sheds so I could enclose one of the sheds and have the center for the MH if not fulltime at least for service especially the roof AC's. The more open the bigger I can go because we can pass through it if needed and not box us in so in the meantime.
Those one are loaders are really neat. They were the quick connect of their day. :D
Does a Ford 7710 with cab have A/C? Is it available?
   / What older model Fords would you look for (40-80hp)? #35
I did a little research and the 7710 I'm looking at has a Super Q cab. Is A/C only installed in it as an option, or will it always have it, or is it something you can add later? If it has the Super Q cab is the 7710 really a 7710 II?
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
DEUTZ MARATHON...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2007 Yamaha Rhino 660 (A56438)
2007 Yamaha Rhino...
