Injector removal tool - (cheapskate version) - photos
/ Injector removal tool - (cheapskate version) - photos #1
California
Super Star Member
An hour north of San Francisco
Yanmar YM240 Yanmar YM186D
First, I don't recommend this if you intend to re-use the injectors. I had new replacements on hand so botching the old ones wasn't a concern.
This tractor is a YM240, same as a YM2000, two cylinders. I paid $107 each for new Yanmar injectors from a local truck/farm injector house.
I thought I could put a little tension on the old injectors and pop them out. I cleaned a bolt that matched the fuel-return threads and threaded it in by hand to learn how deep it would go (8 1/4 turns). I think at this point the injector is contaminated and shouldn't be returned to service without professional overhaul, in case metal fragments got into it.
Then I threaded the holddown nuts flush to the top of the studs, put on a plate I had with a 1/4" hole, found a spacer (socket) that let the top bolt go in 6 turns, and pulled some tension on the center bolt. Hah. All I accomplished was to bend the plate.
Plan B. I used the tractor's holddown bracket to better support my top plate, and started from the bottom of the threads on the holddown studs. This still didn't apply enough force before I reached the point where I expected I might strip threads. I gave up and went to the front (#2) cylinder.
The front cylinder was easier. Threading the nuts upward to make tension then rapping on the injector with a brass drift while prying upward with a heel bar was enough to make it start moving. But even after it lifted a quarter inch as shown in the picture, it was still a heavy press fit clear up to the top of 1.5 inch lift I needed to get it out of its bore. I didn't dare damage the middle and upper part of the holddown stud threads (needed for reassembly) so I kept swapping spacers above the center bolt and moving the holddown nuts down before making each quarter inch lift.
Finally I applied the same technique on the more difficult rear injector. I used different nuts because I feared stripping threads and didn't want to botch the original holddown nuts. Also because of no clearance to swing the rear wrench when using its open end, I put a 12-point box end on each nut before installing my 'injector puller'.
Pulling all the tension I could get on both wrenches I finally heard it pop loose. The snap was so severe I thought I had snapped a holddown stud, but of course they are in compression, not tension.
This injector was so stiff all the way out that rocking the injector by alternately turning the front and back nut was the only way I could make it move.
When I got it out I saw I had sucked the threads most of the way out of one of the temporary nuts I had used. I'm glad I didn't use the tractors original holddown nuts for this. The studs must be better steel; their threads were unhurt.
The bores in the head were jammed with burned carbon so the new injectors wouldn't go in. This took a long time to chip out. I dropped a big washer down the bore to protect the recess down there where the 'insulator' (gasket) fits. After cleaning the bores, the injectors are only about .010" smaller than their bores that they slide into.
The grooves for the 'insulators' (teflon sealing gaskets at the bottom of the injectors) were clean. The insulators had lifted out intact with the injectors. I can see where cleaning the groove down there in the head that centers them would be difficult if they had disintegrated.
The manual emphasizes fit the fuel lines to the new injectors before tightening the holddowns so the fuel fittings align properly. 14 ft lbs torque on the holddown nuts.
The results were as hoped, the tractor starts easily again. As I described in another thread, I think I carboned up the original injectors running 90% biodiesel (B-90) for a year and the spray pattern had become a squirt.
The manual says to test injectors by viewing the spray pattern, spraying against a sheet of cardboard and with adequate protection to avoid getting diesel injected into your skin. (I used a heavy welding glove and a big piece of cardboard to get my hand far from the spray). So far as I could see all four injectors, two old and two new, all sprayed the same pattern - vapor with a center spurt. It seems that professional testing would be needed to distinguish a bad spray pattern.
Ok, now it's good for another 30 years.
/ Injector removal tool - (cheapskate version) - photos #2
Good for you. That's using the old noggin,lol.
Hopefully i'll never have to change mine out but if I ever do I know how to do it now.
/ Injector removal tool - (cheapskate version) - photos #3
Letting the engine blow them out can be very dangerous and will bend sheet metal one guy found out in his PU. After that he used a piece of plywood.
Glad your safer system worked out well.
I never seriously considered blasting them out with compression - after my neighbor told me using Ether in the older smallest Caterpillars occasionally will break the injector retainers and shoot an injector clear across the pasture. :laughing:
I thought that technique might loosen the two lower chamber components that are beneath this removable injector. I didn't want a compression leak down where the head would have to go to a machine shop to pull and reseal those components.
/ Injector removal tool - (cheapskate version) - photos #5
Very informative post, thanks.:thumbsup:
/ Injector removal tool - (cheapskate version) - photos #6
I hope I never need this info, but THANKS for putting it down with first class pics to boot!!!!
That is a GREAT tutorial! :thumbsup:
/ Injector removal tool - (cheapskate version) - photos #7
Nice documentation and pics of the project. What are you planning to do with the injectors you took out? If you don't need them for a core charge and weren't going to use them again, any chance getting a look at the inner workings?
Here's the injector diagram from the YM240 Parts Manual. The Service Manual cautions to disassemble only when submerged in diesel (I assume to prevent corrosion) so I thought I would preserve these intact in case I ever need a core.
According to the Service Manual it should be possible to clean the nozzles if you can find the right materials: "polish the orifice only with a wooden stick lubricated with mutton tallow...". How's that for Old School! I love this tractor. It really is designed for overhaul by the owner if needed, anywhere in the world without benefit of modern technology. They don't build them like that any more.
/ Injector removal tool - (cheapskate version) - photos #9
I have read of a lot of guys, over the years, loosening the lock-down nuts and blowing the injectors out of a Yanmar with compression, but never, ever, heard of it causing a problem. If no work, they removed the studs and loosened them with a wrench or vise-grips.
Norm, can you show me where it says that?
I researched here and on Google. Everything I read said they come out without too much trouble unless they have been rusted in for decades. These were rusted in for decades.
My neighbor worked as a professional mechanic in a Deere agency (including Deere's Yanmar engines) and owns 20-some diesel tractors used in his larger orchard operation. He does all his own work. He said don't blow them out, that's how amateurs turn little problems into big problems. I'm not aware of any more credible advice.
I started out pulling the studs and trying to rotate them. The intake is too close to get a wrench or ViceGrip on the injectors, plus the flats on the injector don't extend far enough above the cavity. (see the first photo). I tried 16 inch Channellocks at maximum force and that just gouged nicks in the injector (third picture). Rotating this model injector would need a fancy specialty tool to go down in the cavity and grip those flats.
I think a professional puller tool would need to lift under the 'doughnut' where the fuel enters. I thought I was near to ripping the threads out of the top of the injector, which is unacceptable damage and contamination if it is intended to reuse the same injector.
/ Injector removal tool - (cheapskate version) - photos #11
Looks good California! Getting those injectors out without damaging them can be very tough. I'll try to upload some pictures of our puller. We worked for quite a while to come up with a puller to remove the injectors without damaging them. What we came up with was a puller that screws directly into the nut #3 (the part that actually gets stuck). We just unscrew the body of the injector while it is still in the head, screw in a special made fitting into the nut and pull it out. Then just screw the nut back on and you are good to go. It works really well.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
/ Injector removal tool - (cheapskate version) - photos #12
Aaron ,,Is that a puller that you sell or for your own use ??
/ Injector removal tool - (cheapskate version) - photos #13
I started out pulling the studs and trying to rotate them. The intake is too close to get a wrench or ViceGrip on the injectors, plus the flats on the injector don't extend far enough above the cavity. (see the= first photo). I tried 16 inch Channellocks at maximum force and that just gouged nicks in the injector (third picture). Rotating this model injector would need a fancy specialty tool to go down in the cavity and grip those flats.
Here's one, but I don't know how to word it for a decent search. Several guys used to post about it on 6 different forums over the past 9 years, and this is the first I have read of a problem. Aaron from Hoye may even have mentioned it before they got their injector puller.
/ Injector removal tool - (cheapskate version) - photos #14
Well... it started out for our own use a few years ago but, due to popular demand, we had a machine shop build us a bunch and have been selling quite a few of them.
We spent a full week building different tools & trying them. We tried everything. We either stripped threads, pulled injectors in half (seriously), or damaged them beyond repair. This was the only thing that we found that would remove an injector 100% of the time without any damage.
The price listed includes a 10lb slide hammer (the expensive part of the remover kit) but we will soon be also listing just the screw in part (a hardened steel thread adapter for around $10) for those that already have the slide hammer.
Yanmar Tractor Parts: Other
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
/ Injector removal tool - (cheapskate version) - photos #15
I can understand that, I would probably do the same.
I think somewhere along the line every manufacturer figured out how much their dealers could make off of repairs and quit designing things to be worked on by the person that owned it. I guess that is why we all here have 30 year old Yanmars and not brand new Cub Cadet/Yanmars.
/ Injector removal tool - (cheapskate version) - photos #16
I bought Hoyes injector puller a few weeks ago,it works great!A couple of slams and the injector pops out.Great tool!
/ Injector removal tool - (cheapskate version) - photos #17
California
Since we discussed in another thread the differences in noise between 2 and 3 cylinder models, I was just wondering if the new injectors made any difference in the noise level or in the overall smoothness of the tractor.
/ Injector removal tool - (cheapskate version) - photos #18
I guess I lucked out big time when I took out my injectors.I didn't have any problems getting them out.I've got a 1610d three cyl.maybe the 2cyl. are different? russ
California
The significant difference is it starts readily instead of endless cranking. After the first pop where it fires and gains rpm, I would say the difference is trivial. I think the fault with the original injectors was they were spurting blobs of fuel, not sufficiently vaporized to ignite. There was white vapor (raw fuel) coming out the exhaust in huge quantities before it would fire. As soon as it was running it ran ok and any difference now might be my imagination.
It may clank less. At the moment I am running straight diesel with no additives and I think it clanks less than it did with diesel and Power Service a couple of years ago, or with the biodiesel more recently. I never seem to need full throttle for anything, in fact seldom run over 1800 rpm, so horsepower has been more than sufficient with any fuel.
The main thing accomplished was to remedy the difficult starting, which was getting worse even as the weather warmed up.
Man I envy you. And rundogs, who has Aaron's competent remover tool. I was *that close* to giving up and ordering one of those!
I don't own a slide hammer. If I did I probably would have tried using it to pull against a small bolt in the bleed hole on top - and probably would have just ripped those threads out. Aaron I have to chuckle at your crew destroying injectors like a bunch of mad scientists until you finally discovered what works on the most difficult ones! I feel your pain; I spent a whole afternoon fighting with this #@%*! You'll make a fortune on those pullers!!
Now he tells me - my neighbor stopped by and only now suggested I might have put NeverSeize on the outer diameter of the new injectors. (But not on the tip where it seals.) Having any sort of harmless filler in there would prevent dust and liquids from going down in the tight space between the injectors and those cavities that they slide into. However I think pulling and testing the injectors every five years or so (the manual recommends 600 hours) will keep them freed up.
/ Injector removal tool - (cheapskate version) - photos #20
Interesting!
Is there a warning in this about using biodiesel?
UNUSED JCT DUSTLESS BLASTER (A62131)
UNUSED JCT...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
2025 Quick Hitch Skid Steer Attachment (A61567)
2025 Quick Hitch...
2017 Ford F-250 Service Truck (A61568)
2017 Ford F-250...
2010 Chevrolet Silverado Pickup Truck, VIN # 1GB5CZBK9AZ259877 (A61165)
2010 Chevrolet...
BUNDLE OF (1) TOPLINK & (2) LIFT ARMS (A62130)
BUNDLE OF (1)...
