Comparison New guy needs help.
/ New guy needs help. #1
huntfish
Maine
New guy needs help 3320 or 3520
Hi guys, I'm new to the site and looking to get my first tractor. I've narrowed it down to I think to the JD 3320 or 3520. I own 80+ acres of woods and fields with some pretty good hills. It will be used for bushhogging, snowblowing (I have a long driveway) skidding small trees, tilling, log splitting and general work around the house.
A couple of my friends have 3320's and love them.
In looking at the 3520 I noticed it's turbocharged. Is that really a "must have" to justify the added expense?
Any help is appreciated, thanks.
/ New guy needs help. #2
I just ordered the 3520. It was only 2K more than the 3320, and 5 more HP for the engine and PTO.
/ New guy needs help. #3
Re: New guy needs help 3320 or 3520
huntfish
Welcome to the forum.
I'd go with the "more hp", but also think you could save the $2k and put it into attachments. If you are short on horses under the hood, then you can decide later to opt up a notch or 3. :)
Whatever you get, you will find those times when a few more horses are desireable.
Me...I'd go right to the 3720 and not look back. :D
The only thing that has kept me from trading in my 4300 for a 3720, is the folding ROPS being standard. I don't want it, as it is too high to get in my garage doors. I'd either ruin a door forgetting (not going to take that chance) or I'd remove the ROPS at the hinge (not smart, IMO). So Deere lost this customer with their decision to drop the fixed ROPS. My loss too. :(
/ New guy needs help. #4
I think a 3000 series is too small for 80+ acres, I would go with a 4000 or 5000 series tractor. Realizing later that you bought too small of a tractor and then trading up is way too costly. There are alot of threads here where guys are wanting to move up in size only to loose money on their trades and also being saddled with implements that are too small for the larger tractor.
I would look at tractors from 60 to 80 hp with attachments to match. Buy it once and buy it right is the least expensive way to go, then keep it for a long time. Good tractors can be kept for longer than cars and pickup trucks.
/ New guy needs help. #5
I don't know your budget constraints and I'm not real clear on the kinds of jobs (how much tree clearing, wood skidding, snow plowing, snow clearing) you have in mind for the tractor and your 80 acres.
Eighty acres is a whole lot of work for a 35hp tractor... Do you have pastures, hay, mowing - how many acres?
If you have more than 10 and plans for more than that - I'm leaning towards at least a 4000 series machine - minimum.
Steve is on the money with the observation regarding the problems of buying too small and then upgrading later. You'll take a big hit in the first 5 years if you decide to sell.
Sometimes, it's better to go bigger from the getgo - 'cause it's better to recoup your investment after many years of happy ownership versus losing money right off the bat 'cause the tractor didn't meet your expectations.
AKfish
/ New guy needs help. #6
I got a 3520 2 weeks ago, 12 acres. I agree with AKfish that it may be small for 80 acres. Glad I did not go with 3320, wish for 3720 but budget constraints. I do like this tractor very much but the other posters are right about purchasing implements in that you may find that the 5 foot implements that are just right for the 30x20 series may be too small for what you have in mind. I can comment more on the 3520 as I see other posts in this thread that relate to your questions.:)
Thanks for all the thoughts guys. Now I'm leaning more towards the 3520 or maybe even the 3720. My land is 90% woods with 2 small fields and a very long driveway. I also am going to be clearing some land for some small food plots. My wife and I are planning on building our house their in the near future and I've got her convinced that I NEED a tractor. :D
/ New guy needs help. #8
huntfish
Good plan. My Deere 4300 (only 32 hp) does very well logging, but need to watch the slopes.
The 3520 (the 3720 better) will handle a log winch attachment like the Farmi winch, and bring logs up or down slopes. Forks for the FEL will find many uses that one can't figure out how he got along without them. Use them more than the bucket.
/ New guy needs help. #9
Huntfish,
I would rather go with a 4120 than a 3720, weight is your friend. If you need to do much clearing at all you will find you need more weight and traction than a 3x20 is going to provide. My 4520 with weights (no water ballast) weighs about 5500lbs. and I consider this to be marginal for the work you are doing. Stumps are more easy to deal with using a backhoe though.
/ New guy needs help. #10
I would think that jenkinsph is correct as far as the larger series will have more weight and power, so it depends on how fast, and how much you want to clear.
/ New guy needs help. #11
Shoot... if he's gonna clear trees and stumps, etc. And build a house -- a TLB -- that's the ticket!!!
Yup... Hurdle right over the 3000 series and leap-frog the 4000's, too!
A JD 110! :thumbsup:
Ok, maybe that's a little too hard on the pocketbook... BUT, when I priced the 4120 configured as a TLB (400CX and 485 BH) it was only a little more than $4k to sit in the seat of the 110 - with ALL the options.
AKfish
/ New guy needs help. #12
I agree AKfish, side by side with the 4x20, the 110 seems to radiate strength, the extra heft of almost all components is remarkable, if it came a factory cab, I'd spend the extra money myself.
Vince
/ New guy needs help. #13
There was a time when a full time farmer used a horse for 80 acres. Then during the 30's he might have a John Deere model 'A' or 'B' ( 20-38 hp ).
Be realistic about how much real seat time your going to have. The 3032E & 3038E both offer a lot of value for the dollars. For the difference in tractor cost, you can get more attachments. Or if money is no object, take a look at the 9630T - 530 hp....and make Tool Time Tim Allen proud.
/ New guy needs help. #14
Vince
Vince,
You know I don't think who's factory the cab is made in is that big of a deal. The tractors such as the 110tlb are made from parts made here and abroad so why not consider a cab made in Canada? I can think of worse places to get the cabs from. Having the Laurin cab beats having an open station and after 5 years I have no regrets. If Deere did not offer a cab for the 4520 then I would have purchased another Laurin cab for it too.
/ New guy needs help. #15
'Course there was a time when folk's had "more time", too! With horses and mules - you'd better have lot's of time.
The old, JD A's and the rest of the 2-cylinder "poppers" did speed the work up; considerably..
The 110 talk was really "tongue in cheek". I wouldn't really consider the JD 110 if I had 80 acres and planned to intensively farm it; personally. I'd rent an excavator and a small dozer to clear the land and keep my sight's set on a 65hp "green" tractor with FEL.
That's a very capable sized tractor for most hay work and smaller row crop acreage - IMO. And it's not so big that you can't use some of your CAT 1 implements, too.
AKfish
/ New guy needs help. #16
AKfish,
I can easily envision a 110 and a 5000 or 6000 sized tractor working together on 80 acres. Just depends on what you want to do and how fast. Atleast I should say that is the direction I am headed in for my next tractor. I think a 110, 4520 and a 6115 would be just right.
/ New guy needs help. #17
AKfish,
Steve;
I couldn't/wouldn't disagree with that approach at all... However, the financial constraints that I have to work with turn the "3-tractor plan" into just another "pipe dream"!!
That said, I think that's how most of us "get where we're going" -- we start out with 1 tractor that can do most of what needs to get done - just takes more time... like the mule and a JD A!
Then we get a little further ahead - and another 20-200 acres - get another tractor!
I was just thinking of what size/type of ONE tractor would "get most of what needs to get done" on an 80 acre parcel of trees with a couple of fields and plans for more fields!
AKfish
BOX OF " NO TILL" DISCS (A65054)
BOX OF " NO TILL"...
2012 STEPHENS CRUDE PUP TRAILER (A67714)
2012 STEPHENS...
Unused 2022 Loftness 14CFISV3 Auxiliary Hydraulic Oil Cooler Skid Steer Attachment (A66734)
Unused 2022...
2021 JOHN DEERE 304L WHEEL LOADER (A65056)
2021 JOHN DEERE...
213063 (A64276)
213063 (A64276)
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
