Pto speed
/ Pto speed #1
GFwoody00
After having my 1500 for a couple weeks now it really seems to be a good tractor, i have become pretty good with the box blade now after several attempst at my driveway. I am going to pick up a 4 foot bush hog today that i found on craigslist. I was wondering what speed does everyone usually keep there tractor in when bushhoggin. I assume my pto has two speeds, neutral and i can bump it up or back. I am not sure if it needs to be pushed up or pulled back, Thanks. Jeremy
/ Pto speed #2
If you have the owner's manual it should have your PTO speeds listed for a given RPM...they'll usually give 2 RPM readings with the corresponding PTO speeds.
/ Pto speed #3
YM1500 PTO Speeds
1st 639 rpm
2nd 828 rpm
3rd 1097 rpm
@ 2400 rpm
I would run it in 1st @ about 2100, that should be close to 540 rpm.
You do need to use an overrun clutch.
Danny
/ Pto speed #4
YM1500 PTO Speeds
1st 639 rpm
2nd 828 rpm
3rd 1097 rpm
@ 2400 rpm
Danny
Look at the decal on my 1610 D,
but maybe there is someone who can translate the japaneese (speed? or what ever) what is written beside the gearnumbers?
Stefan
/ Pto speed #6
Hi Danny, the speed of the PTO was Known at the speed of 2500 RPM.
I was thinking of the japaneese singns after the "gear sheme" :confused:(left side of the pic).
Stefan
/ Pto speed #7
most US implements are designed to turn at 540rpm, anything faster can and will destroy the gearbox over time. Danny gave you the best info, gear 1 @ 2100 rpm.
overrun clutch is well worth the money...if you don't know what that is or why you need it....when you press the clutch in the blades on the mower will continue to turn and can push your tractor forward as it spins the PTO and transmission. The overrun clutch is like a ratchet it stops the force from entering the trans. Without it you will not be able to change gears (it will grind really bad if you try until the blades stop spinning) or stop fast enough to avoid hitting say a "fence", been there done that, went out and bought one before I finished mowing that day.
2018 PETERBILT 520 6X4 T/A GARBAGE TRUCK (A66091)
2018 PETERBILT 520...
TEST YOUR BID BUTTON! (A64278)
TEST YOUR BID...
2025 Vicsec 30in. Bucket Mini Excavator Attachment (A64553)
2025 Vicsec 30in...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2003 Jeep Wrangler 4x4 SUV (A64557)
2003 Jeep Wrangler...
