Kubota accessorizing?
/ Kubota accessorizing? #1
vwkismet
So. NH
I am thinking of buying a Kubota B7800.
Can someone give me an idea how much it might cost to have the tires filled? Alternatively, should I just get a weight box or box blade or something to hang of the 3-pt hitch for ballast?
Also, the bucket on this tractor is a bit bent on top. What is the best way to weld on reinforcement and/or hooks to the bucket? Any idea of cost?
If anyone is reading this thinking of some must-have accessory that I should know about - now would be a great time to let me know! :D
Thanks - I'm just trying to get a handle on my immediately-after-purchase costs so I don't get shocked when I dump another grand into it right after buying it!
/ Kubota accessorizing? #2
Only One grand? :D:D
Personally, implements are a better place to put my dollars than a ballast box. A box blade will give you ballast and you can actually use it for something.
/ Kubota accessorizing? #3
As everyone always says box blade as more uses and provides you with weight compensation as well. As far as welding a hook in the bucket, when I got my BX1860, I asked dealer to weld it, they put a retaining plate and welded the hook so good and it looks like factory done, paid 50 bucks
/ Kubota accessorizing? #4
I'd suggest having the tires filled with Rim Guard, non-corrosive and doesn't freeze.
Depending on how bad the bucket is bent, you may be able to clamp a piece of angle to it and straighten it as you weld the angle to it. This will give you a solid place to weld some bucket hooks.
Since you are welding to the bucket anyway, might as well just spend that thousand dollars on an ATI Tach-all and weld a Skidsteer adapter to the back of the bucket.
I suggest loading the rears AND having some weight on the three point when doing any loader work.
/ Kubota accessorizing? #5
All good advice; jobs are going to dictate your implement needs in the end. Good luck.
/ Kubota accessorizing? #6
steering wheel spinner, hydraulic top link, wider front tires if you plan on a lot of loader work and buy your attachments very carefully considering the planned uses for them.
/ Kubota accessorizing? #7
If you fill the tires, that may be enough rear ballast, it just depends on how you use your loader. I'd plan on fillling the tires with rimguard costing $200, but might be less. I wouldn't buy a box blade just for ballast. If you think you need one, it makes good ballast.
Lights also make a nice add on. If you install them your self, less than $100.
/ Kubota accessorizing? #8
If the top of the bucket is bent that is no big deal. You can try to push it straight with a jack if you weld a flat surface inside to push on and put a couple of 2x8's in the bottom. I mean make the surface parallel with the bottom of the bucket. When done cut off the piece from the bucket weld a piece of flat bar or angle iron is better on the top and weld hooks onto that just like in the Ductape's picture. DO NOT buy a ballast box. You can make you own with a beat up garbage can, some steel, and several bags of concrete. It will cost you about $50.
If you describe what you are planning to do with the tractor people will be able to give specific advice on implements.
ps: here is a picture of how I straightened the cutting edge on my tractor. It had a considerable "smile" when I bought it and it is now near perfect. I didn't need two jacks but I didn't want to point load the metal.
/ Kubota accessorizing? #9
When I read the title of this thread, I thought it was about fashion, etc., so I suggest a Kubota hat might be your first purchase! :D:D:D But, seriously, you've got to look at what work you expect to be doing to figure out where to put your "accessorizing" money.
Considering you are in NH, where you have serious winter, snow removal comes to mind, so things like ballasting the tires, chains, and blades or blowers should probably be on the list.
Beyond that, well, there are hundreds of different implements and attachments available. What are you planning to do with that 7800? Mow? Landscape? Garden? Dig trenches or stumps? Build a fence? Etc., etc. If you give people some hint of what you expect to be doing on what kind of property, they'll probably be able to give you some specific ideas on this.
Fair enough everyone. I was wondering if there was anything that simply everyone wanted to have!
I am going to be putting in some fruit trees, working forest trails, maintaining driveway, and chipping everything in sight!
I have a buddy that can help with lights. I want to fill the tires. I will probably get a back blade for snow removal and a York rake for driveway and trail work. Finally, a chipper will be key.
Would a tooth bar be helpful for my trail maintenance?
If anyone has other ideas they are all appreciated.
/ Kubota accessorizing? #11
Wheel weights or tire ballast help hold the rear end down when using the FEL. But, one still needs counter weight on the 3 pt, of some kind, to lever weight off the front axle. The rear axle being the fulcrum. I've been reading some of our guys' stuff. :D There are some real physics minded engineers who post here.
Ah yes, implements. Without them, what is a tractor, really?
/ Kubota accessorizing? #12
For me, a toothbar is a necessity for unearthing.
Load the rears with Rim Guard. I am not sure what the cost is but it's just almost a must to load the rears, with or without a loader. I mow in a steep embankemnt and depend on the loaded wheel weight to hold me steady. Otherwise, I'd not get on the embankment.
I have the B7800 and it serves all of my rural needs of mowing and what-nots. The loader is a very useful tool.
/ Kubota accessorizing? #13
Watch this and look at the others to see what is possible with your B7800! I am loving mine, the L4350 is getting a bit jealous I think. Just tilled up a couple of food plots for a hunter, he was pretty happy!
/ Kubota accessorizing? #14
Here's another vote for a toothbar on the FEL. Maybe not quite as cool as the Loader Buddy, but it increases the effectiveness of the loader for dirt work by a factor of two, at least, and it's not that expensive.
For your driveway and trail maintenance, the box blade may be a less costly alternative to a York rake. As mentioned before, it is a good weight on the rear for ballast, and it's good for leveling and removing potholes in gravel road, trail, etc. It does take some practice getting it adjusted properly, and it's not as good for snow clearing work vs. a regular back blade.
If you plan to use the tractor to accumulate/move material to feed the chipper, something like that Loader Buddy, or a grapple would be very useful. I make do with some clamp on pallet forks, but they have been very effective moving logs and brush.
Best of luck... and put up some pics when you get that tractor!
/ Kubota accessorizing? #15
That loader buddy seems like a good tool if you have a number of acres to clear of rock and small trees but it sure is expensive. I would say a quality tooth bar is more versatile for your need. I used a York rake for maintaining my driveway but it only works well when the gravel is at least slightly loose and not too wet. All in all it worked OK but I had no other use for is so I sold it. There are lots of threads about box blade use. See if it would fit your overall need better. The rear blade works good for snow and leveling loose material. The chipper is plane fun. Hard work but fun.
/ Kubota accessorizing? #16
+1 on the toothbar. It made a big difference on my L3400.
/ Kubota accessorizing? #17
Hello,
I have a m59 kubota which i had back tires loaded with a material that prevents flats completely solid. the next wk i ran over a small stump which punctured the tire, if i had filled it with liquid i would have been stuck in the woods! cost was much higher around 1500.00 for all four tires.
Also the wallenstien bx62 wood chipper has made short time of trail clearing for me.
Good luck
2015 Hitachi ZX210LC Hydraulic Excavator (A61572)
2015 Hitachi...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2006 Sea Ray Sundancer Boat w/ Loadmaster Tri-Axle Boat Trailer (A61574)
2006 Sea Ray...
2017 Mack Semi (A64047)
2017 Mack Semi...
