Buying Advice Does BX1860 can have cab, A/c,heat, radio?
   / Does BX1860 can have cab, A/c,heat, radio? #1
smokey_truck
Fairfax, VA
BX1860
I was curious to know if anyone sells for cab, A/c,heat, radio? And how much should that setup cost. Any idea pls?
Ganesh
   / Does BX1860 can have cab, A/c,heat, radio? #4
go at google and write curtis cab and you will find what your looking for hoop it will help you. mario
   / Does BX1860 can have cab, A/c,heat, radio? #6
I don't believe you will find a cab with A/C for your tractor.
   / Does BX1860 can have cab, A/c,heat, radio? #7
Ganesh
Not to start another argument:
The Eclipse line of tractor cabs from Laurin
in Quebec, Canada are what you are looking for.
They can be ordered with heat, air conditoning, radio,
lights and lots more there is thread with a price here for them.
   / Does BX1860 can have cab, A/c,heat, radio? #8
I dont know if the BX electrical system will handle an AC unit. I may be wrong but that draws a decent amount of power doesn't it
   / Does BX1860 can have cab, A/c,heat, radio? #9
you can't put A/C on a BX. you don't have enough HP or room for a compressor, nor the electrical power for a self contained unit. You can do a cab with heat.
   / Does BX1860 can have cab, A/c,heat, radio? #10
I would think you have seen enough custom stuff done to know it can be done. You could put a blown hemi in one if you wanted, its just a matter of its not worth the money to put A.C. in.
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56436)
2022 Brush Wolf...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
