Need and education
/ Need and education #1
gilbertson
Member
Suffolk, VA
Satoh
I have a set up coming that I would like to fit on my mini backhoe, it is a .91 cubic inch variable dispalcement pump, with 2 motors that are 16.4 cubic inch displaement. being the novice that I am I was wondering if some would enlighten me on what this means and what size motor I would need to run the setup. Back how weighs less than 600 lbs and I dont need it to move fast but a little *** would be nice.
Thanks
Vern
/ Need and education #2
Thanks
Vern
So you are setting up a hydrostatic drive.....
Looks like you got the pmp and the motors set up for high torque output...
I asuume the motors are 16.4 CUI each...so that will make 32.8CUI combined...
Your full speed, hydrostatic gear ratio (volumetric) will be 32.8/0.91=36.0 then depending on actuyaql working pressure there will be losses in both pump and motors (slippage)....I count 90% efficiancy in pump and motors at max pressure (highest travel resistance)and 95% at normal tarvel....
0.90x0.90=0.81% >> 36.0/0.81=44.4
0.95x0.95=0.90% >> 36.0/0.90=40.0
So you can count your full speed, hydrostatic gear ratio between 1:40 to 1:44
So at 4000rpm your motors will turn 90-100rpm at the most.
or 22.5-25 rpm on motors per 1000rpm on pump shaft
A couple questions.
1. What does a variable displacement pump do? The one I am getting has a lever on the side of the pump.
2. what can I relate cubic inches to in layman terms?
Thank you
/ Need and education #4
To make things simple, lets say your variable pump is 10 cubic inches (big!!). With that varable pump you have the option of when you rotate that lever of using 10 c.i. per revolution when wide open down to 0 c.i. when in idle position. The pistons in side are either using very short strokes in idle, and long strokes in wide open position.
Cubic inches, take your galon of milk out of fridge. That represents 231 cubic inches. So wide open on pump it would only need to make 23.1 revolutions to consume 1 Galon.
I hope that helps.
Let me see if I get this;
231 cubic inches with a .91 cubic inch pump would have to make 254 revolutions to pump a gallon or 4.72 gallons per minute at 1200 rpm?
/ Need and education #6
Gilbertson, math looks right although I did'nt check it through. I can't seem to do math anymore with out calculator!!!!!!
/ Need and education #7
A couple questions.
With that lever you can vary the displacement (travel speed), from zero to max, both forward and hopefully also reverse
1 fl Oz=1.805 cui
1 usg =231 cui
How are you going to steer this thing??
I am going to install spool valves to operate the motors forward and reverse.
/ Need and education #9
Are you sure that pump you is not BI-directional???
...if it is bi-directional, you wont need valves for forward reverse...but then you would need a closed loop setup...
Bi-directional pump can reverse the flow and that way reverse the motor..
Bi-directinal pumps are used on riding lawn mowers....
/ Need and education #11
Pump says CCW so do not think it is reversable.
Then you will need a directional valve for Forward/Neutral/Reverse....I would go with an electric solenoid valve, and use a 3 position switch to choose F/N/R....speed will be by the pump lever, if one motor/tire/track slips, I would use brakes to transfer power to motor/tire/track with traction....
A variable flow divider would be another solution.....
/ Need and education #12
The pump could still be bi-directional. The CCW is the direction of rotation of the input shaft, but if the pump is bi-directional, then the flow can be reversed without reversing the directional of rotation of the input shaft.
suppose to be here tomorrow, so will see then, thank you all for your help
2013 CHEVROLET 2500 HD (INOPERABLE) (A65643)
2013 CHEVROLET...
5 SHANK V-RIPPER, 3PT (A64277)
5 SHANK V-RIPPER...
Stout Brush Grapple 66-9 (A66285)
Stout Brush...
53ft Reef Trailer (A65563)
53ft Reef Trailer...
1996 International Paystar 5000 Log Truck (A62679)
1996 International...
Skid Steer Post Auger (A65640)
Skid Steer Post...
