The Bota Cave
/ The Bota Cave #21
... the work surface has T-Nuts throughout the bottom which allow me to anchor my bench vice, benchtop drill press, chain saw sharpener, cut-off saw, among other things.
Does the Toyota have T-Nuts too?:confused2:
/ The Bota Cave #22
COMmunistCAST made me shut down the web server I was running on my home PC (breaking the picture links from my previous post).
Here is a repost of the pictures of my pallet racks that were in the posting with the picture of my forklift:
/ The Bota Cave #23
I likey...all that stuff around that pretty red bird would worry me to death though!!
/ The Bota Cave #24
It makes me a little nervous too, but I move it before getting anything on or off the shelf above it.
/ The Bota Cave #26
great use of space......makes me want a small forklift!
if you don't mind me asking, how much was that forklift? is that the search criteria you used?
/ The Bota Cave #27
It was $800. My search criteria was based on price and size. I wanted to spend under $1000. I need something that could lift at least 2000 lbs, but wanted it to take as little space as possible. I also wanted something that could maneuver in a small space. This fit the bill perfectly.
It also can easily pick up either end of my tractor to put on jackstands if needed. I've used it to pick up the back end of my G1800S to put wheeled dollies under the back so I could move it (inside my shop) with out starting it (the hydrostatic transaxle has not neutral like a larger tractor).
/ The Bota Cave #28
great thread from both of you....i kind of mixed up the original poster with you and combined my message....haha:confused2:
either way, the rack storage is great....i have one section of this stuff and love it.....BUT i can't access the very top nor clear to the back....pallets would take care of this.....engines, blocks, transmissions, etc......put it all on the pallet it belongs with.....love it....
i might have to ad one of these to the list.....lot cheaper to use existing upper space that is wasted....
/ The Bota Cave
I do like the forklift and sturdy shelves. The one element missing is the casters which afford dollies the ability to perfectly align 3ph connections. I've been pondering how to have pallets with wheels such that the top of the platform isn't too high when connecting to the 3ph and also a way to prevent the pallet from rolling off the shelving system.
/ The Bota Cave #30
I still have the wheeled dollies I kept all this on when it was on the floor. It is easy enough to use the forklift to lift an implement off a pallet and put it back on the wheeled dollies. Most of the stuff I have on pallets is only used occasionally anyway.
/ The Bota Cave #31
Bump for all newer viewers since this was originally ran and for us older users that now have more of the stuff shown to try and store it best. Thanks Tom and other contributors.
/ The Bota Cave
Well thanks John! That's awful considerate of you. I'll try to see if I can get some more photos up. Thanks for all the great info you share too.
I still think there ought to be a seperate forum for garages, shops, and mancaves (or doghouses) as the case may be. I used to know this guy at Lake Tahoe. His wife kicked him out of the house so often, making him sleep in the garage, that he built himself this little "doghouse", more like miniature luxury bachelor's pad, right on the edge of the lake! Tile floors had radiant heat; lakeside was all glass; little fridge, little fireplace, little sauna, 1 bed, magazine rack fully stocked (no such thing as DVD or VCR in those days-see how old I am).
MARKER LIGHTS (A64276)
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
