STX46 gas leak
/ STX46 gas leak #1
BGT
Member
I've got gas....ummmm, well, the mower actually has gas coming from somewhere, and I can't figure out where.
I've already replaced the tank and fuel lines with new. Bottom of the carb is dry. Area around the inline fuel filter is dry. Visible fuel lines are dry.
Mower resides in the garage and there is no gas puddle on the concrete but when I start it up, it then makes a puddle, followed by drips as I exit the garage. It starts fine and runs fine.
Anywhere else I can check for this leak?
Thanks.
/ STX46 gas leak #2
Thanks.
Fuel pump, if it has a Kohler engine
/ STX46 gas leak
Patches, you are correct: Kohler 15hp. Didn't even know the thing had a fuel pump, but then, I'm not mechanically inclined in the least.
I googled the problem, and found another thing it could be is the float in the carb is sticking, allowing fuel to leak into the cylinder while it's sitting. Maybe that would explain the fuel being blown out of the muffler when I cranked it yesterday.
The solution to that problem was given as a carb rebuild kit, or simply turning the fuel flow off at the inline fuel filter when finished for the day, which is what I did.
I suppose the test will be if it still spits fuel out the muffler today, it must be the pump; otherwise, must be the float.
/ STX46 gas leak #4
My STX is gravity feed. The original float needle valve on mine had an elastomer (rubber) tip that went bad. The replacement was solid brass, and never sealed as well as the original.
I always shut off the fuel valve when the engine is not running.
/ STX46 gas leak
Must be that needle valve. After sitting overnight with the fuel shut off, I turned on the fuel and cranked her up yesterday - no signs of fuel mist or spill. Guess I'll have to start shutting mine off too. No need replacing it if it doesn't work much better.
Thanks again.
1995 Crosley 20ft. 3 Ton T/A Equipment Trailer (A61568)
1995 Crosley 20ft...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
UNUSED WOLVERINE QC7-26-12.5G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
INOP/NON-RUNNING 2004 Freightliner M2 106 Medium Duty Day Cab Truck, VIN # 1FUBCXDC24HM93001 (A61165)
INOP/NON-RUNNING...
UNUSED WOLVERINE TD-13-36R STUMP DIGGER (A62131)
UNUSED WOLVERINE...
