Vickers pump
/ Vickers pump #1
mmurphy
Anyone have a good website on older Vickers pump parts, casting #323806? It is variable piston for hydro.. I have been searching for a couple days and can not find it.(parts, or that #) Main reason being it is a early to mid 70's bobcat skidloader. Thanks, Marty.
/ Vickers pump #2
Marty,
are there any other numbers on this unit? With only the 6 digit number given you will probably have to find a good distributor in your area that can help you research the parts. Numbers may be stamped on the mounting flange.
Maybe try going to Eaton hydraulics website. They did have a pretty good listing of Vickers hydraulics in the form of what they called a "900" catalog / CD. You may or may not be able to find the number listed there.
Another option is Attica Hydraulics by Detroit. They are a rebuilder of hydraulic components with a fairly extensive knowledge of Vickers items.
Best of luck
Roy
/ Vickers pump
Thanks, Roy. I will try Attica and see what they may have for me. Them are the only numbers on these pumps. I searched the Eaton site and could not come up with anything either. I may have to do the old fashion thing and actually make a phone call!!!!
/ Vickers pump #4
Marty,
if Attica can't help send me a PM and I will see if any of my old Vickers contacts will still talk to me. Been 8 years since i worked for Vickers distribution so there still might be one or two people that will talk to me.
Roy
3-Pt Disk (A66285)
3-Pt Disk (A66285)
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
APPROX. 5000bu GRAIN BIN (A64277)
APPROX. 5000bu...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
2022 TEXAS PRIDE DUMP TRAILER (A65643)
2022 TEXAS PRIDE...
Schuler Feed Wagon (A66408)
Schuler Feed Wagon...
