Posthole Digger How do you attach PHD to your tractor?
/ How do you attach PHD to your tractor? #1
Redneck in training
Elite Member
South Central Iowa
TYM 330 HST with FEL
I struggled with attaching my PHD to the tractor but I think I found good and easy method now. I lay the PHD flat with the gearbox supported such a way that end of the top arm will be just about at the height of the top link bracket after the draft links are connected to the draft pins. (Pic 5 and 3).
Then I lift or lower the three point, move the tractor forward/backward or push the PHD until the top link bracket is aligned with PHD top arm.(Pic 4). No heavy lifting or brute force is required.
/ How do you attach PHD to your tractor? #2
Hang it.
/ How do you attach PHD to your tractor? #3
Most PhDs I know, you just show them the machine and they will think it is cooler than anything they've ever done in the lab. They will be attached until they lose interest, might or might not get much work done.
/ How do you attach PHD to your tractor? #5
That doesn't sound bad at all. We just bought a used PHD and were trying
figure out a way of storing and hooking it up without hanging it and that
just might work.
/ How do you attach PHD to your tractor? #6
I had a Bush Hog PHD with the optional parking stands that put it in a similar position to the pix shown by Redneck. It still was a PITA to hook up, and after getting it stuck in our claycrete up to the gearbox one day, I said the heck with it and traded it in as a down payment on a lawn tractor.
just might work.
The trick is to figure how high the support under the gearbox should be before you take the PHD from the tractor.
To take it off the tractor I put the tip of the drill bit on the ground and lower the three point to the lowest position and slowly back the tractor. It will fold the drill bit and lower the PHD arm to horizontal position. Then I measured the distance from the ground to the gearbox and added about 1.5" to it. I cut the support from a large post and placed it under the GB. Then I somewhat lifted the three point so there was not tension on the top pin so I could slide it out. While the PHD was on the ground and disconnected I chained the drill bit to the PHD arm so I could lift it chained to my FEL and place in the shed.
I used to have the PHD hanged but this works better.
/ How do you attach PHD to your tractor? #8
I just back it up to a post in the barn, chain it in place, disconnect and drive away. Reverse procedure for hookup...takes 5-10 minutes and no lifting involved.
/ How do you attach PHD to your tractor? #9
I just screw it in the ground for storage very easy to hook back up.
/ How do you attach PHD to your tractor? #11
my friend who i borrow it from i screws theirs about 1/2 to 2/3 into the ground then disconnet it, under their pole shed.
/ How do you attach PHD to your tractor? #12
I hang mine in a shed and just back up to it simplest thing I could think of.
Steve
/ How do you attach PHD to your tractor? #13
For years growing up, our PHD spent it's off time chained to a nice straight tree in the pasture. Pole of a shed would work too if it needs to be stored indoors. If inside on a solid, flat floor, a simple stand could be welded up to hold the boom up at nearly the right height to get it pinned to the top link bracket without a lot of trial and error...
/ How do you attach PHD to your tractor? #15
Many responses on how to store a PHD; however thought you question had to do with hooking up to 3PH. If this is the case go to Everything Attachments - Skid Steer Attachments, Tractor Attachments, 3 Point Hitch Attachments, Farm Tractor Implements.
and check out their videos.
/ How do you attach PHD to your tractor? #16
I find mine pretty easy to handle with the auger removed. The guy I got it from screwed the augers into the ground (long story; I borrowed it then ended up buying it) & when we made the deal the 2 remaining augers were at his place but the digger was about 140 miles away at my place; we like to never got the augers out of the ground.
Lew
/ How do you attach PHD to your tractor? #18
I use a engine cherry picker. It goes up, down, left, right, anyway you want...
/ How do you attach PHD to your tractor? #19
That's worked for me for the last 30 years.
Mf
/ How do you attach PHD to your tractor? #20
Hey Mantis
Couldn't help noticing your lathe in that pic; looks like a "really neat oldie"? Please tell us about it.
Lew
PORTA POTTY (A67714)
2021 JCB 3TS-8T TELESKID (A65056)
2021 JCB 3TS-8T...
10ft Fork Extensions (A66734)
10ft Fork...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
2000 Ford F-250 4x4 Service Truck (A66736)
2000 Ford F-250...
2015 Ford F-350 Knapheide Service Truck (A66736)
2015 Ford F-350...
