Hydraulic Drive system.
/ Hydraulic Drive system. #1
socoj2
Hey guys, someone on a welding site i am a member of said they had some knowledgeable people over here.
I am building a Hydraulic Driven Tracked ATV.
The problem im running into is i dont know all that much about hydraulics.
So i have a 24hp Horizontal shaft motor. The other Caveat is that i want to Electronically control the thing.
So i know i need the following:
1. Electronic Solenoid Valves
2. Proportional Electronic Flow Control?
3. Pump
4. 2x Motor
5. Resevoir
6. Radiator?
7. Lots of hoses and assorted fittings.
So shopping surplus center i sourced the following:
motor
2x
https://www.surpluscenter.com/item.asp?item=9-6239&catname=hydraulic
pump
1x
https://www.surpluscenter.com/item.asp?item=9-6664&catname=hydraulic
Valve
2x
https://www.surpluscenter.com/item.asp?item=9-4677&catname=hydraulic
2x
https://www.surpluscenter.com/item.asp?catname=hydraulic&qty=1&item=9-4070-1
Flow Control
https://www.surpluscenter.com/item.asp?item=9-5178&catname=hydraulic
I dont think the Solenoid Valves pass enough Flow to keep up with the motors how ever. So is there some sort of pilot operated control valve i can use in addition to them?
Also are the motors and Pumps Sized appropriately to go with my 24 hp Engine?
/ Hydraulic Drive system. #2
/ Hydraulic Drive system. #3
How large a vehicle will it be. Just for instance, on my Dixie Chopper, I have a 25 HP Kohler engine driving a transmission with two hydrostatic pumps and two hyd motors. It can turn on a dime. It can drive this machine at up to 10 MPH, and cut grass, but you do not normally cut grass that fast. It's going to depend on the weight, torque of the hyd motors, friction of the tracks, and the weight of the person.
Have you considered a variable speed pump on each side with it's own pump, motor, and valve setup.
Truthfully now. As i had no clue about the varaible speed motors and they usually cost an arm and a leg more.
What usually controls the variable part of these motors?
Vehicle weight should be 2k lbs. Rolling resistance is probably going to be about 150-250 lbs.
/ Hydraulic Drive system. #5
Soco,
their are companies that make small hydrostatic pumps that are electrohydraulic controlled. These might be a better choice for you since they will only create the flow you require for the speed you require.
Companies that come to mind are:
Sauer Danfoss,
SAMHYDRAULIK - SAMHYDRAULIK
Eaton
rexroth
By trying to use all individual components I.e. directional valves, flow controls etc.. the plumbing and weight become a real issue.
Worked with some individuals years ago attempting to do this and they ended discovering that the inexpensive route didn't work very well.
Also word of caution: Some (most) wheel motors are inefficient so keep that in mind when sizing components also.
Roy
/ Hydraulic Drive system. #6
Maybe this will help explain hydrostatic pump. My pump has a lever that moves in fwd and rev to control the amount and direction of the fluid.
Hydrostatic transmissions
Soco,
Sauer Danfoss,
Eaton
rexroth
Roy
Not that i want to disagree.
But if i am creating a side by side drive with out electronics.
Normally i would have 2 motors. 2 pumps. 2 Control valves and 2 resevoirs.
Now if i want to control it electronically. im just increases the valves to 2 Inline Solenoids and 2 Flow Control valves.? Is there something im missing?
I have never seen an aftermarket electrohydraulic motor, Ebay Surplus center etc. The problem with a new engine is i dont have $4000-$5000 to spend on one.
/ Hydraulic Drive system. #9
socoj2,
Not to scuttle your project, but have you thought this through using the selected components. The motors you selected will need 15 GPM each, and the reservoir minimum should be 15 gal just for one side. That pump will pump 19 GPM each side, for a total of 38 GPM, at 4000 psi. HP required to work that pump is about 104 HP. I think only high end machinery would use proportional valves, but in a different hyd configuration. A new DA solenoid proportional valve if they even make one, would cost upward of $1,000 plus.
Not to be nosy, but what kind of money were you planning on putting in this project?
I started doing what you are doing, collecting parts for a hyd machine many years ago, and I now have a bunch of parts such as cylinders, pumps, and motors. Very few people can just collect parts and throw something togather and hope it works , and sometimes they succeed.
socoj2,
Well like i said. I dont know much about hydraulics. The motors i linked are probably vast over kill for what i want to do. Which is why im doing the research to begin with.
Surplus center has a electronic flow control valve that is up to 15 gpm and 3k psi for <500. and im seeing similar on ebay for under $300.
JJ. you have beena huge help!
Given 24 hp, needing to drive 2 systems what Pump/motor combo would you go with?
/ Hydraulic Drive system. #12
On a typical HST drive system that is mechanical you would only have 2 pumps, 2 motors and one reservoir. No valves are required if you are using a variable displacement True HST pump. Only one reservoir is required also.
If you are looking at a standard fixed displacement pump that has an inlet and outlet and planning on using proportion directional control valves for controlling speed and direction you making a system that will burn lots of horsepower and create lots of heat doing nothing.
Explanation to the best of my abilities.
Using a fixed displacement pump that provides 10 GPM @ 3,000 PSI which will give you travel speed of 10 MPH.
If you want to travel at 2 MPH you must divert 8 GPM of this oil to tank. If you are using proportional control this is usually done with a valve called a hydrostat block which senses pressure in the work ports and meters flow across your proportional. Now if you are climbing a hill that requires a system pressure of 2,000 PSI the extra 8 GPM is being dumped to tank also at 2,000 PSI which equals about 9 HP wasted power in heat.
Same system using tue variable volume HST style pumps will probably have around 1.5 - 2 HP loss. This is from the charge pump and inefficiency of the system.
Does any of this make sense?
Roy
/ Hydraulic Drive system. #13
Hope you continue the project.
/ Hydraulic Drive system. #14
Roy
AGREE 100% with you Roy!!
Why not use proper pumps when they are available!
The simplest systems work on a 1500$ ride on mower!!
/ Hydraulic Drive system. #15
just wondering how the project is coming. Im interested. There is another posting here by a david duvono on a tracked dumper. He is doing a similar project.
/ Hydraulic Drive system. #16
Lots of good but (confusing to me), information here. Some of the information above, regarding 10gpm pump having to divert 8 gpm if you want to go 2 mph. I would think that in an ATV like vehicle, you would want to throttle down the engine driving the pump to control speed. On a mower you want full speed to spin the blades and so I can see where you would need a different set up to control the speed. On an ATV or in my case a tracked dumper, the only work is moving the thing, it takes little GPM to dump, so I would expect good performance dumping at idle with the kind of pumps we are going to run. In SOCOJ2's example he went from 450 ft lb motors to 85 ft lb motors. I don't believe he would get much ground speed. I would be pleased if my unit would match the 7.5 MPH top speed of my Kubota B4200.
/ Hydraulic Drive system. #17
In other words and correct me if I am wrong, If my ATV can go 10MPH at 3300 RPM driving the pump, could I not go 3.3 MPH at 1100 RPM if the rolling resistance does not change? My pump produces 2500 PSI at 1000 RPM (planning 2:1 reduction) so 1100 engine RPM will turn my pump at 550 RPM. Max speed I will run my pump is about 1850 RPM (max speed rating 3000RPM). I have less then $150 into pump and motor so if it does not work I will go to plan B. thanks
/ Hydraulic Drive system. #18
Diverting or throttling flow for low speed usually means that you use more energy(100% heat) for the by passed oil than the oil used to travel forward...
It can be OK if you can deal with the excessive heat in the system, increased fuel cost and limited control of speed and torque.....
/ Hydraulic Drive system. #19
Your theory is correct for the most part. One concern might be will you gas engine have enough power idled down to do the work? Your pump will still generate the same PSI regardless of RPM input.
I guess you won't know unless you try.
Best of luck
Roy
/ Hydraulic Drive system. #20
I bought a 723 CC 27 HP twin cylinder Briggs and Stratton. Its a verticle shaft engine so I am hoping that the pump will have no issues operating on its nose? I am told that to operate my pump I would need Min 15 HP. Thats the good thing about building things yourself, if something does not work, cut it out and put something else in.
