MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,678
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
I've read lots of R1vsR4 tire threads and I'm just about to buy my new tractor. Probably a Bobcat CT225/230 or 235
I have 1000' gravel driveway with one medium sized hill about 200' long. I have to grade it after each heavy rain and my current 2wd with FEL 16cyl tractor with R1's can't pull any material up the hill. Even dry I can't drag up the hill.
Would R4's in 4x4 on a 30-35hp tractor be ok to pull gravel up the hill or would I need R1's.
The other uses of the tractor would be for wood gathering/moving in wooded areas. No grass cutting though with R4's it would be easier to make shortcuts across the grassy areas. Snow removal would be with the back blade and probably chains if I go with the R4's.
Thanks for any thoughts on this.
DO NOT GET THE CT225, it is short on hp for what you need to do. I would get the 235, plenty of power for those up hill pulls. R4s are fine, you may need chains, will depend on ice situation. While R1s would be your best bet for the winter, I would prefer the R4s for grading the dirt on the drive and making those short cuts across the grass, but that may just be me.
I have a Mahindra 3215HST and it can pull a full load in the box blade up hill without trouble. You should have no problems with a CT235 in my opinion.
