3-Point Hitch stump grinder on PTO shaft for BX1860?
   / stump grinder on PTO shaft for BX1860? #1
smokey_truck
Fairfax, VA
BX1860
I have like 4 stumps to grind, is there like stump grinder on PTO shaft for Bx1860 size tractor, I can rent or buy if it is cheap? I need some ideas from the Gurus here
Ganesh
   / stump grinder on PTO shaft for BX1860? #2
Ganesh
Rent a grinder from a rental center, or hire it done. It is reasonably dangerous work. Your pto hp is 13 and a smidge. No reason to bother with it, imo.
   / stump grinder on PTO shaft for BX1860? #3
I have 5 to do and rather than buy one for my BX24 I will rent one for 100.00 this weekend. Cheap enough and its not something I will probably ever use again. I would have duy them with the BH but I didnt want a 4 foot hole in my lawn when an 8 inch hole will do.
   / stump grinder on PTO shaft for BX1860? #4
I rented one last year to do 4 stumps. If I recall, the unit had a 20hp Honda GX motor. Though a gas motor, more hp than what's available at my 1860 PTO. Don't think I could have rented one around here for my BX.
Alright, So rental is the way to go and so I will do it
Ganesh
Looks like I will just rent a small standalone one from the equipment rental and used it and return it too
Ganesh
   / stump grinder on PTO shaft for BX1860? #8
I rented one last week-$100. A Husqvarna...13 HP engine. Thing worked great. Only problem with the one I rented was it wasn't self-propelled...YIKES! Had to drag it all over the place, up and down hills. Had to hand-winch it up the ramps back into the truck when done.
Took 20 minutes or so to get the hang of it because I couldn't see the grinding wheel and where it was making contact. Soon realized you have to do it by feel. Also finally figured out the brake is to lock one wheel only so that it helps you pivot it left to right as you grind. Try it for 8 hours and see if you don't sleep well that night!:laughing:
   / stump grinder on PTO shaft for BX1860? #9
   / stump grinder on PTO shaft for BX1860? #10
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
275 GAL HORIZANTAL SKID TANK (A48992)
275 GAL HORIZANTAL...
4 New Toyo Tires 205/60/16 (A47371)
4 New Toyo Tires...
2000 INTERNATIONAL 4700 (INOPERABLE) (A48992)
2000 INTERNATIONAL...
JBM T800 Mighty Dumper Dump Wagon (A49251)
JBM T800 Mighty...
45030 (A48082)
45030 (A48082)
