bx23 or jd4200 loader and backhoe
/ bx23 or jd4200 loader and backhoe #1
CHENO
Which would you reccomend? They are basically the same hp and specs. different color.
/ bx23 or jd4200 loader and backhoe #2
They are not the same at all:confused2:
The JD4200 is a mid-framed CUT while the BX is a sub-CUT.
/ bx23 or jd4200 loader and backhoe #3
I just goggled the Kubota BX23. It is quite a bit smaller than a John Deere 4200.:)
I have a 4200 with fel, mmm and a number 7 hoe. It was used with 900 hours when I got it but there has not been enough time spent on it or others of the size to make any comments other than I really like it and so far it impresses me.:D
What does sub cut mean?
/ bx23 or jd4200 loader and backhoe #6
The 4200 should have more GPM at the rear hydraulic outlets and a higher loader lift capacity. You're not looking at the "right" specs....
/ bx23 or jd4200 loader and backhoe #9
In other words a BX23 is half the tractor a 4200 is....
Not sure I'd put it that way..A little bigger in size..3 more horsepower. Also, it appears that it came in 2x4 or 4x4..Manual or hydro. The 23 only comes one way..4x4 and hydro. Physical size doesn't mean much unless your using large impliments. My BX23 runs circles around my previous 8N, which was probably 3 times the size. All in what you're going to use them for.
I moved a tri-axle load of limestone last night and 25-30 heaping one ton dump truck loads of dirt on Saturday...Not too bad for something this size.
/ bx23 or jd4200 loader and backhoe #10
Half the weight, half the loader capacity, half the 3pt lift capacity, half the rear tire size, half the hydraulic flow.... probably half the year adjusted new price too. So its half the tractor. Approximately.
But sure, a BX23 is a fantastic little machine if thats what your needs call for. I'd rather have the Deere 2210 in that size but that is also half the tractor.
Giyi GY-STB47 QA Telescopic Boom (A60463)
Giyi GY-STB47 QA...
RING 2 STARTS HERE @ 9:15 AM (A62130)
RING 2 STARTS HERE...
CFG NT18K (A60463)
CFG NT18K (A60463)
2015 Kenworth T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59908)
2015 Kenworth T680...
Kubota ZG222 (A60462)
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
