Stirrup?
/ Stirrup? #1
Inky05
Kubota BX24, Kubota L260
Does anyone make a Stirrup for the HST pedal on a BX24?
I get tired of moving my leg so far to change directions...
Also might help with the jerky stops in reverse???
/ Stirrup? #2
On my Bx, I just slip my foot under the pedal and lift up with my toes. It hurts a little bit if you don't have boots on.
/ Stirrup? #3
I welded a piece of 2" square tubing on top of the reverse pedal...made it a lot easier.
/ Stirrup?
Been doing that too... just thought a strap or stirrup would be nice.
/ Stirrup?
I don't understand... or see how that would help...
The two are too far apart. I would prefer a simple rocker pedal.
/ Stirrup? #6
Check out the local bike shop. They may have a stirrup designed for bicycle pedals that may be easily retro-fitted.
Otherwise I'd take a look at bending one out of strap iron, and tack welding it to the pedal. If you do that, make sure it's big enough to fit your winter booties!
/ Stirrup? #7
It's still a rocker pedal...it allows me to go forward or reverse without taking my foot off the pedal...the piece of tubing is used to decrease the distance fore and aft.
/ Stirrup?
So I guess a top view would look sorta like this:...?
/ Stirrup? #9
Close...same principle...it also decreased the amount of force required to engage...for some reason (never really dug into it) reverse travel seems a little stiffer and it helped with that (right knee is arthritic).
