Oil & Fuel Bypass oil filter for those that care
   / Bypass oil filter for those that care #21
You can find used ones on Ebay for fairly reasonable prices. You can save even more by building your own with a used pump.
Ken
   / Bypass oil filter for those that care #22
Speaking of used pumps, I wonder if a used power steering pump would work. Basically, we don't need a lot of pressure, just enough to move things over the filters.
Plus a steering pump plus V belts would give one the chance to optimize the performance of the pump.
What am I missing?
Just thinking out loud...
All the best,
Peter
   / Bypass oil filter for those that care #23
On on board "filter cart" could easily be made with a 12V pump if you only ran it when the oil was warm. It is the cold oil that requires a powerful pump. Hard to find room for it though. Seems like this would be much simpler than the steering pump.
If there was a cheap dependable bypass setup where only say 15 psi went to the filter and the rest did not create a significant back pressure on the pump making it work hard, the PTO filter would make some sense.
Ken
   / Bypass oil filter for those that care #25
I never saw that post - how well does that pump work with cold oil? The thermal protection on my used tuthill pump sometimes kicks in when the temps are below 20. This winter, it will be in a heated area (50), so it should not be an issue.
Did you ever do the quick disconnect setup? I used some 3/4 flat face fittings on mine. One could even use o-ring seal hydraulic fittings with female caps for when it is not being used.
Ken
   / Bypass oil filter for those that care #26
I think the simplest solution is to adapt a high-pressure filter (with a bypass) to connect to the front PTO. 8 GPM (or 12 GPM or more, on the larger PTs) and it wouldn't take long to circulate all your oil through it, even though the filtered oil is dumping back into the tank and mixing with the unfiltered oil. I'm not a mathematician, but it seems like 10 to 15 minutes of run time occasionally, and you'd have well filtered oil...
   / Bypass oil filter for those that care #28
And the prize for shirt cuff calculation in ball parking the right number goes to... Envelope please, KenT!
The math is pretty straightforward, if you don't split nits. Each minute filters a fraction R of the tank, leaving 1-R unfiltered. Each subsequent minute filters that ratio again, giving the amount of unfiltered oil as (1-R)*(1-R) and then
(1-R)*(1-R)...(1-R)
Or
(1-R)**N is the amount of unfiltered oil after N minutes. i.e. if y= is the fraction unfiltered oil, then
y=(1-R)**N
or
log(y)=Nlog(1-R)
or
N=log(y)/log(1-R)
For a PTO running at 12gpm for a 40gallon tank, it takes a little less than 20 minutes to get to less than 0.1% filtered, running at wide open throttle. Mathematical nitpicking would push the number closer to 25 minutes. (Hint think APY.)
Now WOT might require warm oil, but the math is unchanged unless the relief kicks in.
All of which lead me to wonder about the utility of doing this offline...
All the best,
Peter
   / Bypass oil filter for those that care #29
You need an affordable, reliable bypass setup that can handle the full flow and pressure of the PT and yet have a low enough relief setting to not destroy the filter. Maybe I am always looking in the wrong places but I have not found one. Surplus has one with the low end relief adjustable down to 125. Maybe then put a lower pressure one after that that can get down to the filter range? I am starting to get nervous already. Any idea what the pressure would be midline in the run when the PTO is in full bypass. The flows are so high i bet it is close to, if not above, the filter rating (media, not the can) even though the end of the line is open. If that is true, then you would need to run a separate return line back to the tank.
Or am I thinking about this all wrong?
Ken
   / Bypass oil filter for those that care #30
Ken
I don't know if these would qualify as "affordable", but this brand has filters that can handle up to 6,000 PSI spikes and has bypasses as low as 50 PSI...
This is just one example of what's out there -- keep in mind that Surplus Center is essentially handling "closeouts and overstocks" and may not be representative of the overall marketplace...
http://www.donaldson.com/en/ih/support/datalibrary/000630.pdf
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
78'' SKID STEER BUCKET (A56857)
78'' SKID STEER...
