Smokey 5103
/ Smokey 5103 #1
deerefan
louisiana
1952 8N, 2005 JD 5103
I cranked my tractor after it sat for a few days and it billowed white smoke, ran rough (barely ran), cleared out after a few seconds and I idled it up. After about 10-15 seconds it ran fine. Is this common? It did stay rather cold here a few days and from past experiences with diesel generators I think this is normal. After a short warm up, the tractor ran fine. I guess I am asking if this is normal, just a little skeptical b/c the tractor only has 25 hrs and is about 4 months old. Thanks for the input.
/ Smokey 5103 #2
I don't think it is of concern while you experience colder temps. That model doesn't come with any factory pre-heater or block heater, unless installed by the dealer. These new engines are acting different in a lot of ways, due to the design to meet emission requirements. Ask somebody with the large frame compacts, 4120 up thro the 4720, and they will tell you that these are nothing like the old yanmar engines in the 4510-4710 tractors.
/forums/images/graemlins/cool.gif
/ Smokey 5103 #3
The smoke is from incomplete combustion, my 990 does the same thing I just let it warm up for a few minutes before I take off and get to work.
/ Smokey 5103 #4
I can get smoke too (with the Yanmar diesel) if I don't hit the glow plugs long enough, or if the previous time I ran the tractor I didn't get it good and warm before shutting it down.
As long as it clears up after warming up, I would treat it as a normal condition. The incomplete combustion comment was right on.
Appreciated hearing about the comment from Dutch. I think many of our engine experiences are changing based on the excitement from the EPA and the regs they hand down. Once such an organization exists, it will continue to come up with new restrictions just to justify their existence, if for nothing else. Happens with all govt. agencies.
/ Smokey 5103 #5
Yep, some white smoke is normal as the temps drop. I think that's an EPA Tier 2 engine, which is the newest requirements. Nothing to worry about.
/ Smokey 5103 #6
My 5203 does the same thing--cold natured beast. But after a bit it smooths out. /forums/images/graemlins/smile.gif
/ Smokey 5103 #8
My brother's 5103 does the same thing. It is normal. Most diesels will billow white smoke on startup if they are cold. Make sure you are in a well ventilated area.
/ Smokey 5103 #9
is it normal to do when it's 75 degrees outside and have not been used in a week?
/ Smokey 5103 #10
You can loosen the injection pump, turn it slightly clockwise, and retighten. Advances the timing and white smoke should clear right up. Not a rare problem with 5003 series tractors. Happened on about 20-30% of the 5003's we sold.
Mark the pump and housing before loosening any bolts and you'll have a "reset" in case you turn it too far.
/ Smokey 5103 #11
will this same thing work on the 5103's????
/ Smokey 5103 #14
i am also interested. my 5203 isn't blowing out any white smoke that i recall when it hasn't been ran in awhile. i get more of a light black smoke when it first starts up but only for 1 second. maybe it's due to not getting that cold in SC? although we did get snow this year:laughing:
/ Smokey 5103 #16
My 5203 is a 2004 model - one of the earlier ones without a turbo. It has a Stanodyne fuel pump with a "cold start advance" to automatically advance timing when the engine is cold.
This spring, I found the wiring from the cold start advance switch / thermostat pulled loose -- likely from a branch or limb. I reattached it without any trouble and tucked it a bit deeper behind the fuel pump.
I don't know if the newer 5X03's have a cold start advance, but I thought I'd mention it.
/ Smokey 5103 #17
how did it run with out it plugged in? did it smike when it started with it unplugged
/ Smokey 5103 #18
I discovered the disconnected wiring when doing a visual check this spring. I repaired the wiring before starting the tractor, so I didn't get to see how it would have behaved with the wiring disconnected.
Wooden Rocking Chair (A61569)
Wooden Rocking...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A63109)
THIS WILL BE A...
2010 Deere 318D (A60462)
2010 Deere 318D...
2024 John Deere 408R Sprayer (A63109)
2024 John Deere...
330 GALLON POLY TOTE W/ CAGE (A62131)
330 GALLON POLY...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
