Loader ford 6600
/ ford 6600 #1
mastertractor
changed all 4 12 foot hydraulic lines from a 777b ford loader to the fittings behind seat. they connect to tubing on the loader. the bucket moves very slow now, and the 3 point hitch is slow too. just bought this used 1976 model tractor and trying to find out if there is a trick to changing lines and/or if i have to bleed anything. sure could use some help.
thanks from pete
/ ford 6600 #2
thanks from pete
Have you checked the hydraulic oil level?
/ ford 6600 #3
As for the loader, you have introduced a lot of air into the loader circuits when you changed 4 12ft hoses. You need to cycle the loader circuits repeatedly until the air is purged from the system. Then check your hydraulic oil level and replenish as required. Then see what the 3pt does.
/ ford 6600
probably didn't purge enough. will try again tomorrow when i get off work. thanks for the knowledge.
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2022 EZ-GO ELITE...
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 HINO 195 18FT...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2013 KENWORTH T800 BOBTAIL VACUUM TRUCK (A65643)
2013 KENWORTH T800...
(2) SUPER SAVER HEATERS & PARTS (A64278)
(2) SUPER SAVER...
