92 3500 or 90 350
/ 92 3500 or 90 350
/ 92 3500 or 90 350 #42
You need to upgrade that factory 2" receiver. I have broke the one on my 04 F-250 with the same ratings. Get a Titan 2.5" unit. They are rated at something like 15,000# and 17,000# WD.
The other big issue with 2" receivers is the hardware that you get to go with them. Most is rated at 10,000# or less with few exceptions but if you step up to the real stuff, 2.5", you can get bars and balls rated at 25,000#.
By the way its not just me who has broken the hitch. My uncle did also and I know of a few other guys who have doing heavy bumper pulling. These were not old rusted out hitches either, 2 years old or less on both me and my uncles.
Chris
/ 92 3500 or 90 350
If I got to that heavy of a bumper pull I'll have to consider that. Would be nice to find a gooseneck adapter that fit those rails the 5th wheel is on.. that way i don't have to booger it up to go to a gooseneck, since it has the custom bed.. etc.
soundguy
/ 92 3500 or 90 350 #44
If not available you could have one built or you could convert the GN trailers over to 5th wheel.
Me personally I hate 5th wheel and GN because I like the beds of my trucks. If i had to have one it would be GN and I would convert any 5th wheel crap over to GN.
Chris
/ 92 3500 or 90 350
I talked to the rv place today and they make a gn adapter that will fit the 5th wheel rails.. so when/if I get a gn trailer i am good to go.
soundguy
/ 92 3500 or 90 350 #46
Hi Chris - You've had the truck for a few days now. How is it?
/ 92 3500 or 90 350
I drove it around yesterday. had to order a 10' 7pin extension to make the traielr connection from the bed to a bumper pull. Looked at a gooseneck plate that will attach to my 5th wheel frame rails... will consider getting that when i get my next trailer ( whenever that is ).
truck rides good. I can tell it is heavier than my 250.. don't turn as sharp and is harder to park.. um.. can't go thru some drive thru's too :)
feels 'torquier' though not as quick on the acceleration as the 6.0psd.. but then.. I was prepaired for that, reading a few other threads compairing the 7.3 and 6.0 psd's. on the plus side.. I guess I don't have to worry about it's heads blowing off either :)
finally figured out how to program the clarion radio presets and set the time :)
rpm range is different than the 250. to hit 55mph in the 250 I run at about 1550 rpm once everthing is settled. it's more like 2100 in the 450. IIRC the 250 has more top end rpm on the tach whereas the 450 looks like it's red at 4k or so.
soundguy
/ 92 3500 or 90 350 #49
Hey SG
I just thought of you when I went to Harbor Freight yesterday. There was a newer Dodge sitting on about 38" tires, stacks out the bed, ect ect ect.
Anyway he had a set of nuts hanging off the hitch. When I mean nuts I mean nuts, like from large nuts and bolts. The had to be 4" like the kind used to secure a metal street light or telephone pole to its foundation. He had a piece of chain strung though them and that was it. Kind of a new swing on things, no pun intended.
Chris
/ 92 3500 or 90 350
wife nixed the idea on a beater when she realized I'd likely be driving it out of state on my tractor safaries... ( I'm sure that 90 f350 I looked at would have made it..she wasn't so sure.. :) )
soundguy
/ 92 3500 or 90 350 #51
Soundguy,
Most of the F450's and 550's had some deep gears. I think they started at 4.56 or 5.18. Not sure if you could change the gears out, as thats not the same rear end as the F350s. I believe its a Dana 110.
Enjoy the truck! And don't be afraid to post some more pics!
/ 92 3500 or 90 350 #52
The F-450/550 chassis cabs had either a 4.88 or 4.30 axle ratio. Soundguy's truck started out as a chassis cab and had an aftermarket hauler bed installed. That was the only way you could get a 450/550 pickup until '08 when Ford started offering an F-450 pickup. Those ratios were still offered when the '08 F-450 pickup came out, Ford eventually dropped the 4.88 later in '08.
/ 92 3500 or 90 350
should pull great...
soundguy
/ 92 3500 or 90 350 #54
sweet!
has a class 5 hitch it looks like ont he rear.. 12000/1200 not too shabby. need to get a new trailer now.
I but they don't make an ag trailer like I want in a 5th wheel... ho hum..
soundguy
Sounds like an excuse for a new project.:D Super sweet truck BTW. Ya did good.:thumbsup:
/ 92 3500 or 90 350
I found a reese gooseneck plate that pins on my 5th wheel rails.. for 157$.. so I'll just order that.
funny enough, on the route i drive to work, a decent gooseneck trailer just went up for sale.. is used and maybee ?10ys? old.. but looks ok... might have to stop and measure it and see what i got that will fit on it.. :)
soundguy
/ 92 3500 or 90 350 #56
soundguy
I didn't get to that part of the thread to read about your finding the gooseneck plate until after I had made my post. Still a sweet find on the truck though!
/ 92 3500 or 90 350
I'm happy about it!
soundguy
/ 92 3500 or 90 350 #59
I'm happy about it!
soundguy
How many miles on your F450?
Two of my neighbors have 2001-02 F250s with 7.3L PSDs and around 120K miles on them. Both have had to replace injectors and have had front end jobs.
Any service history on the F450?
/ 92 3500 or 90 350
120k m, all service recordds.
soundguy
