Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I'm still stumping for a cheap 1-ton just to haul a trailer / hay for my farm use.. not a daily driver.
have come across a 92 chevy 3500 96k miles, 6.5td standard cab that I can probably snag for 3500$ has been well cared for sat a couple years after 'grampa' died.. inheritor/ new owner has driven it for about a year and wants to get rid of it for something cheaper / easier to drive.
I'm not thrilled about gm.. or the standard cab.. but.. heck.. it's not a daily driver.. and would be cheap enough.
other one I found down the road is a 90 350 with the 7.3d has a topper I'll need to set off. also good condition.. odom's flipped so it's got either a lil over 100K or a lil over 200K.. truck looks more like 100k.. etc. has crew cab pretty sure 5500$ will sell her.
both have auto trans, air / radio.. etc., etc.
I'm more preferable to ford.. though it is older.. etc.
I assume neither of these trucks will be setup with the nice adapter plug for e-brakes.
f350 has a 4 wire trailer plug int he back meaning I'd need to run the ebrake power, plus a fused power line for a 6 or 7 pin plug.. I think same setup on the chevy.
Question onthe brake line sense wire .. on the brake switch.. I remember reading that some vehicles have an odd setup that you have to be carefull about.
anyone up to date on that? I've never had to tap a brake switch.. have always been lucky and had an option plug on my 98+ trucks.
just wanting to know what I'm getting into either way, or if I should be looking out for a problem on the wireing.
any comments?
soundguy
any comments?
soundguy
