computer backup methods
/ computer backup methods #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
On the previous advice from members, I went out and purchased an external hard drive with one terrabite for about a hundred bucks. I then discovered I was only using 22 gigs of my 80 gig hard drive that includes pictures on it. I could not justify spending the money for such a large storage device as I only want to back up once in case of hard drive failure. I do not swap files in and out of this computer. I purchased some 8 gig dvd's and come to find out, there seems no mechanism on my Windows XP to be able to back up to dvds. My question is what do I need to be able to back up to dvds on Windows XP? Another program perhaps? Is it possible?
/ computer backup methods #2
Do you have a dvd recorder in your pc?
Cdr's would do too they are about 700MB it would take 22 give or take
The usb drive is by far the easiest way to do it in my opinion.
tom
/ computer backup methods #3
Make sure your DVD can burn/write DVDs. Then you can download any number of free DVD burner programs from the net.
SimS
/ computer backup methods #4
Use the Windows Backup utility: Start -> All Programs -> Accessories -> System Tools -> Backup
It's pretty self explanatory after that. Also format the DVD with in Windows Explorer before using it.
/ computer backup methods #5
Arrow,
Most backup software programs are picky about what, where to and how they back up. Windows built in program is no different.
For some reason the home version of windows does not allows you to RECOVER your backups. Don't bother with Windows backup software unless you have Pro.
External hard drive is probably you're most universal, DVD is probably more secure. You can google free programs if you like. Genie-soft makes a pretty good paid version. It's fairly inexpensive, versatile and easy to use. I'd recommend it to my family.
Joe
/ computer backup methods #6
If the DVD media you bought says 8.5 gig capacity...be aware they are "Dual Layer" and not all DVD burners have dual layer capability...likewise with the software that is used for "backup to DVD/CD"...
In some cases you can write to a dual layer disk but you won't be able to read it later or from other machines... the same goes for some backup software...
regular capacity DVDs hold 4.7Gig.
/ computer backup methods #7
No XP Pro here but I do have Service Pack 3. I must have the "special" version of Windows XP Home Edition...
I have Windows Pak 3 as well but does not produce this screen. Instead, it only relates to "restore to a previous point" or "choose your own restore point". No "backup" provision as described for XP Pro as I have XP Home.
Does an outside program such as GFI allow my computer to back up to dvds even though Windows XP Home does not have a support for dvd back up?
/ computer backup methods #9
/ computer backup methods #10
WHAT are you trying to back up?
If you have a very simple configuration on the PC. A system that has had very little modification and few applications installed you might just want to save your data. Save the photos, spreadsheets, document files, etc. If you loose the system you just rebuild it or buy a new one and copy over you data.
Frankly I am not very happy with the quality of software these days. Reading reviews of backup software and finding a good package has not given me warm fuzzy feelings.
I run a backup program, Migo Software, Inc. - PC Backup Pro : Backup PC, save data, backup my PC, protect PC files, data recovery, automated backups, that runs a couple of times a week. Since I have not tried a restore I don't know if it really will work. So I hope that I never loose the hard drive and two if I do, the software will restore.
To backup the backup I copy all of my important data by hand to USB hard drives, USB thumb drives, and DVDs. The only data that I have that really consumes disk space are photographs. Spreadsheets, documents, etc take up very little space. I hundreds of GBs of photos that uses up the most disk space.
DVD backup is problematic if you have lots of data. Cheap DVDs likely have a limited lifetime. I have used cheap DVDs but I have also started to use Verbatim has a couple of different DVD that SHOULD provide a much longer lifetime than the cheaper media.
The system I can rebuild if I have too. Hopefully I will not have too and if I do the backup will recover. If not I have my manually copied files.
Later,
Dan
/ computer backup methods #11
While I appreciate that you don't have that much data to back up, I would still recommend the HP SimpleSave system. Plug it in, accept the user agreement and it automatically backs up all your documents and continues to do so every five minutes if necessary so long as it is attached to the computer. Couldn't be simpler if you are just trying to protect your documents and photographs. It is not a hard drive image type backup so you would still need to reinstall programs and operating system in the event of a HD crash but it is the data that is irreplaceable and it does a fine job with that. The system recognizes over 300 types of document/photo file/music file etc right out of the box so unless you work with some esoteric programs you really don't need to do anything but plug it in and accept the user agreement. Done.
Automatic frequent backup is really important. The trouble with occasional backups is that anything you changed from the last time you backed up (?months ago) is lost in case of failure. As recently used documents are frequently the most important that makes frequent automatic backup an important feature. It is great for things like photos or music files too which are often added to one hard drive then deleted from the original source leaving you unprotected until you do your ?infrequent manual backup.
The HP SimpleSave drives are available in a number of sizes. Amazon has a half gigabyte system (about the smallest) for $80 including shipping. Tough to beat as a cost effective solution for backup of documents, images etc.
/ computer backup methods #12
I bought a Seagate Free agent, I have used it 2 times and now during a self test it says I have to send it in for repairs?? It is an external drive, not sure if I screwed it up or what.
It installed easy enough, I am almost to the point of trying to re-format it, but think I may do more damage since it is pre-loaded with an install kit. Kinda sucks after spending the $80 or so $$. I downloade their "tools" program last night to run a disc scan....wont run...:(
When the wife was working, she needed a backup system for her job. At the time, the simplest and cheapest method was to use a crossover cable to network into another old computer. I still do that today except now I have a small router. A manual file backup only took about 10 minutes.
I do have an almost new unused computer . Was this connection with a usb cord? and what is the procedure to backup to a network computer?
Island, your suggestion is a good one and makes sense. Still have a tough time even spending that amount for what I want to have in case of a crash. There is a part of me that is saying "so what if it crashes" and another part of me that wants a little bit of back up.
Dmace. I'm saving all of my files and email accounts on Yahoo ( do not know how to do the email part) Totals about 20 gig. Is a flash drive more reliable than a dvd?
/ computer backup methods #14
]Is a flash drive more reliable than a dvd?
YES, you can't scratch a flash drive or accidentally erase it by putting it too close to a magnet. Plus flash drives transfer data much faster then a DVD drive.
/ computer backup methods #15
I agree but flash drives are small and easy to misplace. It is also difficult to label them. I guess putting a large 16 or 32gbyte flash drive into a plastic ziplock bag with a printed label as well would overcome that issue.
Flash drive certainly makes more sense than a DVD or CDROM these days.
/ computer backup methods #16
I looked at a bunch of USB Flash Drives today; never owned one but thought I might want to. So what brands would you recommend? I think a 4 gig would be plenty but may go ahead and buy 8 gig.
/ computer backup methods #17
You will find that the majority of flash drives are made by either SanDisk or Kingston. I like to purchase the ones that are sold under those names for piece of mind even though most of the no-name units have the same memory in them. Also, if you are not looking for long-term storage but want to get more out of your available memory, then look into compression software to compress the files before putting them on a flash drive. I don't recommend zipping for long-term storage or backups though.
/ computer backup methods #18
Thanks, Derek. I found that Walmart and Best Buy both have SanDisk at the same price. Office Max has Verbatim for more money. Office Depot had the SanDisk about the same price, but Ativa cheaper. And of course Best Buy had their own no name ones a little cheaper, about the same as the Ativa. I think I'll buy the SanDisk. The sales personnel in all the stores would only say they're all about the same and do the same thing.
/ computer backup methods #19
Bird, they all make different grades of flash drive. I would purchase a higher grade for use as a backup device. In the fine print of the manuals they list the MTBF much lower for the lowest cost ones.
That said, I haven't seen flash memory fail but once. But I do follow my own advice and give it to my clients as well.
/ computer backup methods #20
OK, just one small problem. Being a computer dummy, I wouldn't know how to determine which grade I was getting although I do find a number of different ones on the Internet that I did not see in any of the stores today. And I assume by MTBF you mean "mean time between failure" but I didn't see any manuals for any of them; just the basic instructions on the back of a card. But I had to run to Walmart for something else a few minutes ago, so I picked up a 4 GB SanDisk Cruzer USB 2.0 Flash Drive for $14.88 plus tax for a start.
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
Landhonor Quick Attach Hydraulic Forks (A66285)
Landhonor Quick...
