BX exhaust exit options?
/ BX exhaust exit options? #1
Jabroni
Central MA
Kubota BX24
My BX24 arrived with the little exhaust tip point back towards the rear. This got soot on the cowling. This past week after a thorough soaking in PB Blaster, I freed the tip and pointed it forward. Now it's getting soot on the brush guard. I'm thinking a chrome stack would look great , and would be functional at the same time. Does anyone have a How-To on any other exit options that would soot and heat away from the tractor?
/ BX exhaust exit options? #2
Mine is pointed right at the FEL and it gets soot on FEL. aggravating. I been thinking of making a attachment to go straight down to rail. Missouri thunder made one with chrome stack going up. Another added a heat resistant pvc pipe going down some- can't remember who did. aczlan? achinbac? something like that.
/ BX exhaust exit options? #3
I've got the same problem as Radioman, soot on the loader. I'm thinking of installing an exhaust elbow and directing the exhaust 90 degrees to the ground. Should be able to find one at the local parts store.
/ BX exhaust exit options? #9
Not sure if this would be an issue with the BX but I know the old 8N Fords had a bad habit of starting grass fires with the bottom exhaust. Another problem was they would get pinched or bent if driving over and solid oblect.
If you point them up the pipe should be higher than your head to reduce the noise level and they now become another object for tree branches to tear off.
Roy
/ BX exhaust exit options? #10
Roy
Yep, one of my sons broke the stack on our CX80 on a tree limb.
/ BX exhaust exit options? #11
The BX lower axles are so low and muffler is already a good foot, all we need is a few inches of angled downspout. I been thinking about this problem long before this thread was started. I just cant seem to find a muffler shop that can give me a twist on/off adapter that small. the reason I think to remove easily is the plastic bonnet will need to come on /off when servicing the tractor, and the last thing I want to do is to fiddle with the exhaust removal first.
/ BX exhaust exit options? #12
they have stainless flex pipe you can polish to a mirror finish and bend to fit any where ,lotta work
Mini sweeper attachment (A61567)
Mini sweeper...
2012 GENIE GTH844 TELESCOPIC FORKLIFT (A62129)
2012 GENIE GTH844...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2012 KENWORTH T800 KILL TRUCK (A60736)
2012 KENWORTH T800...
SWITCH HITCH HYDRAULIC HAMMER ATTACHMENT (A60736)
SWITCH HITCH...
