Need HELP with 3 point hitch operation
/ Need HELP with 3 point hitch operation #1
dixie
I bought a used M5700 that came with a M4711 backhoe. The previous owner never used the cat ll hitch, just the backhoe and fel. The M4711 has its own hydraulic pump that works off the pto. I plan on disconnecting the backhoe and install a 3 point hitch in order to connect my bush hog for mowing. With the backhoe still connected I tried lowering and raising the cat ll hitch but nothing happens when I operate the position control lever. I have the 3-point lowering speed knob set somewhere between fast and slow and the engine at idle (approximately 1200 rpm). Can someone give me a jack and jil version of what steps I need to take to get the cat ll hitch to operate properly?
Thanks in advance
/ Need HELP with 3 point hitch operation #2
Thanks in advance
Your 3PTH has never been used and is probably in the up position for years and w/o the lift arms and adjusters on there is no weight to lower them put the lever in lower and turn fast-slow knob to fast and put weight on arms and see if it goes down.
/ Need HELP with 3 point hitch operation #3
Hopefully that's the case, there is no down pressure on the 3ph, uses gravity only.
