pressurized sandblaster
/ pressurized sandblaster #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
I generally do not buy from harbor freight except for certain items.Anyway I have been looking at their pressurized 110 lb sandblaster.The tank seems to be OK.Well what I was thinking was purchasing their tank and then going out and getting a better deadman valve for it.Seems like I might beable to save some money and still have quality so to speak.Has anybody here bought a HF sandblaster unit ????
/ pressurized sandblaster #2
I had one, i could never get it to work right. Always would clog up and was slow. I ended up building one that works much better. just my 2cents
/ pressurized sandblaster #3
I had a friend that wanted one, so he brought me two old freon tanks and I built one for him and one for me. Basically out of scrap. They work OK you need to baby them some, but no more often than they get used we are both happy.
/ pressurized sandblaster #4
I purchased one over 10 years ago. It does work. But, there are a few things to keep in mind. 1. It does require quite a bit of air. 2. The sand or other blast media, must be dry, or be prepared for lots of frustration. 3. It uses a lot of blast media.
With regard to blast media. If the blasting is done on an area allowing the media to be reclaimed, sift out the garbage, and re-used, helps having to purchase a bunch.
Check out TPtools web site. They will be a good source for media blasting equipment, parts, blast media, etc..
/ pressurized sandblaster #5
I bought one from HF and could not get it to work. A friend with a body shop has one for small stuff and told me that it only works right with one type of sand grade and I forget which one he said. ??? It was numbers like 25/80 or something like that. He said his supplier sent the wrong sand once and it kept stopping up.
/ pressurized sandblaster #6
Can't get the d**n thing to work. Constant plugging,
a royal pain. I wouldn't get one if I were you. Wish
I'd known ahead of time.:mad:
Bill
/ pressurized sandblaster #7
Could you please post the for sure media # I will try that before I give up, same problem as everyone else. Plugs up constantly:mad:
Well so much for the HF idea.Will look into the TP brand but did not notice any portable units.How about the ones from Eastwood ?
/ pressurized sandblaster #9
I have the 110# blast tank from HF and have discovered that if I run the lower valve (sand tank) at half volume and turn it off before closing the deadman, I do not have the clogging issues. Still a PITA, but it works.
As another poster noted, it needs A LOT of air and goes through media quickly.
/ pressurized sandblaster #11
I owned a 5 gal. at first traded it back for a 10 gal....I really didn't didn't care for the Deadman valve...yes as mentioned it takes a lot of air to to fill these pressure type....and I could never tell if I had enough sandblast material......until I drained off the air.... shut off all the valves....after 6 months I returned it bought my small plastic suction type... and even with my small less than 4 cfm @90 lbs directdrive piston oil type CH...it works alot better uses less material runs on a minium of 7 cfm than the pressure type....I'd never buy a pressure type again.....when the sandblast material gets low on this cheap sandblaster... and while I'm waiting for the compressor to buid up I can fill it up without the hassels...I also burned out the valve /reeds on a brand new Briggs & Stratton Brute compressor that never shut off using the pressurized types.....I've since built up my own compressor using an 11 cfm twin cyl. cast iron pump and a 1.5 hp compressor duty 115/230 volt electric motor... using the 10 gal. tank and controls from the burned out "Brute" .... last summer I done a lot of sandblasting with my little CH...without any burn out problems.....so I think I'll be fine with this twin cyl.......Ampa......:)
/ pressurized sandblaster #12
IMO, sandblasting is one of the few things that is cheaper to have done professionally... Professional shops can do it 50x cheaper then a hobbiest can....better compressors, ability to recycle media, better blasters, etc... Not to mention, they do this stuff all day long, they know what to watch out for, etc..
For what it costs me to have stuff professionally sandblasted, I cant see ever wanting/needing one....About the only exception to that would be one of those small benchtop self contained blasters for small parts..I can see that being handy for onesie/twosie type stuff...
/ pressurized sandblaster #13
Around these parts sand blasting is very costly to get done. They charge for each bag of media they use even if they recycle it plus they charge by the hour which is usually $45. per hour. I don't think I'd want them to blast my forklift. It took me 9 hours to do it. :ashamed:
I do a good bit of sand blasting both for my business plus my personal stuff so getting someone to do it would cost a small fortune. I built my own pressure blaster that I've used for years with no problems. It's a real work horse. It was featured in the Welding, Design and Fabrication magazine some years ago. I did purchase a cabinet blaster that has it's own recovery/recycling system built in and it's one of the most used tools in the shop. I haven't seen a good store bought pressure blaster yet that I've liked.
/ pressurized sandblaster #14
I have the 110 lb. H.F. blaster. The only problem I have had is when I tried to recycle media. It did clog in the hose due to debris, but that was my own fault. Other than that it has worked fine. Do turn down the media valve as most times you will waste a fair amount of the material. Sand is hitting the sand in front of it rather than the object you are cleaning. Do keep the air valve open though. Some people here use sandbox sand from HD or Lowes. I'm lucky to have my friends trailer compressor (he doesn't have the space to park it at his house). Good Luck, Gene
/ pressurized sandblaster #15
Gotta get yourself a sifter like I use. It lays on the top of the blaster and pour the reusable sand into it and it keeps the crap out of the sand.
/ pressurized sandblaster #16
A trailer compressor would definately help in sandblasting. I have a 125CFM Grimmerschmidt, but it needs some work.
Well I have the place to keep all the equipment.I am getting ready to build a 24x36 workshop with all amenities---welder,plasma,2 stage compressor,sandblaster.I definitely to not want to skimp and buy junk.I worked in a gigantic machine shop as a mechanic so I know what having all the nice stuff is like.I did not look at sandblasters up close so I thought all tanks were basically the same except for the extremities.That is why I thought I could just buy the HF setup and add on the better deadman and assorted parts and be ahead of the game.I looked at the Eastwood combo sand/soda blaster and when it is on sale seems like a reasonable item.I think I am going to build the TP cabinet --- the plywood take off with their plans and line it with sheet metal if necessary.I have alot of farm equipment that I want to restore along with JD garden tractors,so I already have alot of jobs for it.Will keep me off the couch and in better shape.Right now I am drooling over the new Sear's tool catalog that came in the mail.........
/ pressurized sandblaster #18
milkie62 did they have the new miter saw in the catalog, the one with the adjusting fence? I saw the saw yesterday and watched a tv demo of it and it looked like a good idea [for woodworking not metal working]? I use a window screen to screen my blast material before reusing it, but I haven't did enough with it to know how well it works though. I don't remember if mine is a harbor freight unit or not, but I know this you won't use it with a short sleeve shirt on long until you will get proper clothing on. The unit looks like the harbor freight unit. I also have a blast cabinet that does a pretty good job on smaller stuff but I am going to put a strainer in it and do a few other things to it that I haven't done yet. I know you know this so I am saying it for myself if for no one else[ always wear a respirator every time you use it even for the small jobs].
/ pressurized sandblaster #19
Spudland Dave;
There must be some real cheap labor where your located. The cost to farm it out is over tripple what it is for me to do it. Then there is the hauling, pickup, sales tax, double price for media, labor, incidental costs ( ins. plus machine maint. ) They do it when they have enough projects to get a days work. I usually want it done on a moments notice.
I built a blaster out of a stainless 12 gallon barrel for less than a hundred dollars. Yes it is aggravating when it is humid and it plugs but it is part of the game. I can buy metal media blasting for 7 dollars a fifty pound bag. Recycle it three times and use it for fill. Not for everyone... but works best for me.
/ pressurized sandblaster #20
anyone have one of those attachemnts for a pressure washer that lets you spray sand and water at the same time? do they work?
ROME RLS12 HYD SCRAPER (A63276)
ROME RLS12 HYD...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
2025 8in Channel Tooth Bucket Mini Excavator Attachment (A64553)
2025 8in Channel...
2018 International Durastar 4300 Asphalt Pot Hole Patcher Truck (A64556)
2018 International...
HONDA generator (A64553)
HONDA generator...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
