Oil & Fuel Gas tank gasket
/ Gas tank gasket #1
Homebrew
Morgantown, WV
PT 425
Does anyone know if the gasket material under the ring that the gas cap hooks into is a standard material? Mine is leaking. I tightened the screws a little but I don't want to strip them...thought maybe I'd get something a little thicker. This thing uses enough gasoline without it sloshing out of the tank! :)
/ Gas tank gasket #2
Mine leaks too! I don't have a solution, Just don't fill the tank all of the way. It still leaks, but less. I think the tank needs a baffle inside. Anyone have any thoughts on this.
/ Gas tank gasket #3
I fill mine to about 8" below the cap and it doesn't slosh out. It originally came with a SAFE FILL line sticker on it about 6" below the cap, but the gas made the sticker fall off! :rolleyes:
/ Gas tank gasket
I first noticed mine leaking the first time I filled it. I had the tip of the gas can nozzle just under that metal lip. Gas ran pretty much right out under the gasket in a spot where the plastic weld in the tank is quite uneven. It seems like I'm sloshing out quite a bit of gas...especially since I'm still so jerky on the machine controls.
/ Gas tank gasket #5
There have been several types of gas tanks on the 400 series over the years.
Does yours look like this?
/ Gas tank gasket
QUOTE]
Well...hard to tell exactly, but it looks very similar...and that cork looking seal isn't sealing where the seam of the plastic tank is uneven on one side. I may try and tighten down those screws and if they strip, go to bolts. I worry about dropping a nut into the tank though. And I'm not sure what type of bolt won't corrode with exposure to the gasoline.
/ Gas tank gasket #7
Homebrew,
Too bad PT still has not fixed this problem. I went to a autoparts store, bought thicker gasket material and replaced the screws with bolts. Not easy, but it barely leaks now
/ Gas tank gasket #8
Homebrew I brought home my new 425 on the 22nd of April. I was just over 9 hrs. as of switch off last night. After reading your post I inspected mine but saw no signs of gas leakage. I've not filled mine above ~ 3 inches below the top fill line sticker. BTW, our two purchases just about doubled the number of PTs listed on this forum. I'm over near Huntington.
/ Gas tank gasket
PTOuser, I saw your location and almost contacted you last week to see if I could check yours out. My brother-in-law who went with me to pick mine up lives in Teays Valley. But since I had already made up my mind I was getting one, I decided not to bother you.
/ Gas tank gasket #10
Although this is an older thread I decided to bump it back to the top because I am having the same problems with my gas cap, this and no one has said anything for a couple of days. I can't tell if my tank is leaking from the seal or the cap itself. It don't look like it has a breather hole but some type of pressure mechanism in the cap itself. I think the cap is just to tight an the tank is trying to pull in air to equalize the pressure but it is not getting enough. What have any of you done with good results? Drill out the little rattle thing or what? The smell of gas concerns me and my tank looks like Mossroads. Thanks
/ Gas tank gasket #11
I would just get a new cap. Drilling it out is just going to let dust and gunk into your tank, while letting gasoline slosh out into a hot engine compartment...Not recommended.
Many moons ago, I drilled out a gas cap on a problematic engine. It solved the engine issues, but sprayed gas around like cheap perfume on Saturday night...I replaced the cap about one use later.
All the best,
Peter
/ Gas tank gasket #12
My gas tank leaked also. Below is a picture of the cause and the remedy.
Cork is factory gasket, white is my 1/2 gasket. I first tried tightening screws, but soon realized that wasn't the problem. The seam between the 2 halves of the tank is very poor, causing one side to be higher than the other by approx. 1/32". If you look at the arrow in the picture, the white part is the 1/2 round gasket I placed under the factory full gasket and steel ring. The difference in height was much too great for the single gasket to seal. My first thought was to shave off the excessive material, but I determined that was too difficult to do and decided to just fill up the space. It was easier and it worked, gas has not leaked out since the fix and I fill it to within 1" of the top of the tank.
/ Gas tank gasket #13
What type of material did you use for your 1/2 gasket? It does look the same as my problem I am having.
Thanks
Sakai SV505 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 EZ-GO ELITE...
JOHN DEERE 460M SILAGE BALER (A63291)
JOHN DEERE 460M...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
2013 FORD F250 (A60460)
2013 FORD F250...
