belt driven pump
/ belt driven pump #1
heliosik
Hi everyone. I'm trying to figure out what hydraulic motor, and belt driven pump do I need to power snowblower? Snowblower needs 570 rpm, and 28hp to run. I'm gonna run my pump in gmc 1 ton truck with a serpentine belt. Can this be done? Thank's for all the help!!
/ belt driven pump #2
Welcome to TBN
Before we get into specifics, how much money are you willing to spend on this project? You will need a lot more than just a pump and motor.
One of the main problems however is that the pump will have to operate at such a wide variety of RPM's since your engine is not at a constant speed. Snowblowing requires slow moving forward, and at the low RPM there may not be sufficient flow from the pump to get the blower moving fast enough to do any real work.
What is this blower from?
/ belt driven pump #4
Kenny is right,the best way to accomplish this is to have a separate engine driving the pump.
The pump that there was a reference to in the other post is not a good choice,you have a serpintine belt and that pump uses 2 A belts this pump should not be used with any other accessory's PS A/C or ALT on the same belt since the amount of tension required would put a large load on the bearings of the accessories.
/ belt driven pump #5
I was sure he mentioned serpentine belt for his truck, and the pump uses a serpentine belt. These pumps are made for use on large trucks.
/ belt driven pump #6
The main problem is the 2000 RPM requirement...
/ belt driven pump #7
I would be more concerned if he could get his speed low enough to use the blower.
/ belt driven pump #8
Is D1 using automatic transmission, or low range on a manual transmission not slow enough for snow blowing. My 4WD F-250 has a granny gear that is very slow. The truck speed will be determine by the volume of snow one is trying to remove.
2006 Bentley Continental Passenger Car, VIN # SCBBR53W76C033311 (A65563)
2006 Bentley...
2012 Ford F-150 Pickup Truck (A64194)
2012 Ford F-150...
2014 Freightliner M2 106 Water Truck, VIN # 1FVACXDTXEHFU5910 (A65563)
2014 Freightliner...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2013 Ford Explorer AWD SUV (A64557)
2013 Ford Explorer...
John Deere 316 Riding Mower (A66408)
John Deere 316...
