4300 weight
/ 4300 weight #1
jeff408
Randle WA
JD 4300
I need to get a trailer and would like to know approx what my 4300 w/430 FEL and 48 BH might weight in at. My book says the tractor alone weights 2825lbs. Would a 7k trailer be enough?
Thanks, Jeff
/ 4300 weight #2
Remember you need to subtract the weight of the trailer from the 7k figure. A 7k unit my be just on the edge of safely handling it, but I would recommend a 10k 18' trailer to be sure you have a safety margin and a little room to move the tractor to find the best weight distribution. E-brakes on both axles also...
/ 4300 weight
I'm looking at a new trailer that nets 5,500 lbs. Would that be enough for my set up. Anyone have a good estimate on what the tractor w/ FEL and BH would weigh.
Thanks, Jeff
/ 4300 weight #5
NO. That sounds like a lightweight 7k GVW trailer. I would bet that tractor is 5500 lbs with FEL/BH. If you fill your rear tires add 500 lbs.
You want a 10k GVW and 18-20' if possible (as mentioned earlier). More is better here but use caution as the trailers in the 10-12k range get heavy. Then you need to worry about your prime mover (SUV/pickup).
- My old 16' 7k landscape trailer with steel rails and a 2-piece mesh gate (too light for heavy compact tractors IMO) weighed 2100 lbs. 7k Trailer pictures by modified_bob2007 - Photobucket
- My 16+2 (beavertail is last 2) 12k equipment hauler with rub rails and stake pockets and heavy 4' ramps is about 2650 lbs. Yes both have been on a scale. Log Splitter Welding pictures by modified_bob2007 - Photobucket
/ 4300 weight #6
I own a JD4300 w/Front Loader and Backhoe, it has hydrostat trans, and industrial tires. Rear tires are loaded. It tips the scale at just about 5,000 lbs. I have thought about buying a dump trailer to both haul the tractor, and also use it for gravel or dirt. I think it would be very handy. I have looked at a few different makes and have noticed a huge difference in quality. Before I purchase, I would look long and hard to make sure you get a good one and also one with the wheels on the outside of the dump box so that it has a lower profile for easier loading. Also the trailer should have the D-rings built into the bed for easy tie down of the tractor. If anyone does this already any experience would be appreciated.
/ 4300 weight #7
It should go without saying, but I'll say it anyway, any trailer this size need functioning brakes. I can't think of many things less fun than being passed by your own tractor on its trailer. The value of being able to stop with the tow vehicle and trailer in a straight line is priceless.
There, I said it.
/ 4300 weight #8
There, I said it.
I agree 100%
I said it also in my first reply:
/ 4300 weight
Thanks all for your responses. Well I ended up getting a new trailer. I was looking at all the used ones out there and wasn't sure if they would meet all the WA state requirements and if something might be wrong with it. Its a Fab Form with 4 wheel brakes and LED lights 5,590 capacity. I will weight up everything soon and post results.
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2021 BOBCAT T62 R-SERIES SKID STEER (A65053)
2021 BOBCAT T62...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
