Yanmar 1500D Generator
/ Yanmar 1500D Generator #1
KidYanmar
Member
I have a YM1500D.After replacing an aftermarket starter that came on this tractor with an Yanmar starter (Hitachi) I noticed the solenoid is getting really hot after running for a couple hours.The soleniod is new. Could the ignition switch be bad or the generator overcharging?The connections are good to the starter and battery ground to engine is good.
/ Yanmar 1500D Generator #2
Generator charging should have nothing to do with it. Power is applied to the solenoid only when the key is turned to engage the starter.
If the switch were at fault the solenoid, and hence the starter, would be engaged when the switch is in the "run" position.
Are you sure it isn't just being heated by the engine?
Thanks for reply Reb, I just bought this tractor last month,the old starter was burning up when starting,I thought it was undersized.This new solenoid is getting really hot, it would burn you if you were to touch it,the new starter is not getting hot.I only ran it once after installing the starter/solenoid before noticing it.The generator must connect to the battery at the solenoid on the post with Batt cable and white wire.I can't find much info in my YM1500 Yanmar manual (Japanese).I do have a manual for YM135/155 I wonder if they use the same charging system?I wonder if disconnecting the white wire and running the tractor would tell me anything?Or how to test the ignition switch?
/ Yanmar 1500D Generator #4
There is your problem. The generator is charging in AC (like your house). The generator needs to attach to the regulator which converts it to DC first. I'm suprised everything has lasted this long.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
Thanks for your reply Aaron, I only assumed the white wire went to the generator.I found a wiring diagram for YM135/155 and it's white wire goes to the ignition switch.I was thinking that the white wire is the only other connection to the battery besides the starter and must be for charging.The ignition switch at the second key position,must connect the voltage regulator and battery with white wire?
the YM1500 manual in Japanese does have a primitive wiring diagram.It shows white wire to solenoid going to both ignition switch and voltage regulator.This wire must supply battery voltage to ignition switch and get charging voltage from regulator.The wire is called B1 and goes to BAT on ignition switch and to B on starter also to the voltage regulator, I need to know Japanese to know what this connection is called.What would happen if I disconnect it?
/ Yanmar 1500D Generator #7
It should be wired the same as your 155, or any other manual, and as Reb said, the generator has nothing to do with your problem, if you have one. You can disconnect the gen and troubleshoot the starter.
/ Yanmar 1500D Generator #8
The 1500s take different regulators than the 135/155. They have BOTH wires from the generator going to the regulator.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
/ Yanmar 1500D Generator #9
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
/ Yanmar 1500D Generator #10
Don't know about tractors, but I do work on cars for a living so maybe this will help (or maybe not). Cars have one large wire going to the starter from the battery. It is usually 12V (14-15 probably when charging). The other small wire going to the solenoid should have NO power on it unless you are in the start position. This should be easily verified with a DVOM (or test light). If your starter solenoid were getting constant power the starter would be always turning and would likely have burned up by now. :)
Thanks for your reply's.I checker the stater today and the post on the solenoid that connects to the battery,ignition switch and regulator is grounded.This would cause it to heat up!!I hope someone can tell what is wrong, I don't want to connect the the battery to the solenoid if it is going to ground.
/ Yanmar 1500D Generator #12
I'm assuming you checked going to ground with all the wires removed from that terminal. If you did I don't think it can be anything but the starter. If the wires going to the regulator or switch were on there while making this test it is possible they were touching a ground someway.:thumbsup:
/ Yanmar 1500D Generator #13
Are you saying both posts on the solenoid are grounded? ALL starters should be wired similar to this.
Thanks for your responses.I disconnected all wires to the solenoid.The post that connects to the battery, regulator and ignition is grounded.The post that goes to the starter is not grounded.I do not want to connect the positive battery terminal to a grounded solenoid connection.
/ Yanmar 1500D Generator #15
quote "The post that connects to the battery, regulator and ignition is grounded". I may be wrong, but the black ignition wire should be the only wire connected to the small solenoid connection. The battery and regulator wires should be on the big post with the wire from the battery. Thats the way my ym2002 is and I would think they all are. I believe the diagrahm Normde sent shows it that way. I retract the statement about all being that way. I may be misreading your post so take all this as my opinion and good luck to you.:thumbsup:
Thanks for your reply winston1,Yes there is a small terminal with black wire,also the post with battery cable and white wire.The other post goes to the starter.The post with the battery cable and white wire is grounded through the solenoid body to engine.
/ Yanmar 1500D Generator #17
looks like you have zeroed in on a bad solenoid. Does fire fly when you touch the battery wire to the correct terminal with all other wires disconnected?:confused:
Thanks for your reply, I noticed some arching when I connected the battery positive cable.The solenoid was new I only ran the tractor for a couple hours.I checked the last starter I had taken off and it's solenoid post is grounded the the solenoid body also.Is this tractor burning up solenoids?
I think I have figured out the problem and I will post it if you'all can guess what it is or come close.I don't want to admit what was wrong outrite too embarassing.Here are some clues:Checked the generator ouput from the regulator while running 6-11 volts DC, seems OK.Dash lights and fuses all check out fine .Battery fully charged with 12+ volts.When I replaced the starter I had to install new solenoid,the one on the new starter was damaged in shipping, thanks USPS for dropping it.After running for a couple hours solenoid gets very hot, can barely touch it without getting burned.Now if you connect it to battery it gets hot in a couple minutes...........Good Luck!
/ Yanmar 1500D Generator #20
I give up but would sure like to know the answer. I've been embarrased many times!: :ashamed:
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
