Mowing Replacement Mower Blades for BX
/ Replacement Mower Blades for BX #1
techguy2
West of Houston
anyone found a aftermarket supplier for the kubota BX 60 inch standard mowing deck?
Thanks for the info and the welcome!
Long time lurker, but finally decided to sign up.
/ Replacement Mower Blades for BX #4
Welcome to TBN...I bought mine from Kubota...Don't remember them being too punishing as far as price. Besides, how often do you need to replace them. Mine, after 4 years.
I have lots of clay and it is heck on the blades (or rather the crawfish chimneys are). Local kubota shop wants 20 bucks per blade. It normally costs 20 bucks or so to have them sharpened.
I did have one question though..
I have the RCK60B-23BX standard cut deck
and I use the K5371-99040 blades on them.
I can't seem to find them in cross reference for any of the aftermarket blades.
Itlooks like the 96-612 blades will work. Can anyone confirm?
/ Replacement Mower Blades for BX #6
West of Houston? I'm kind of west of Houston... if you add some south in the mix as well... my current house is in Sugar Land, but I've picked up some acreage in Needville.
I love walking through the area after mowing down the crawfish chimneys, and seeing crawfish parts scattered about.:laughing:
/ Replacement Mower Blades for BX #7
You will have a very tough time finding aftermarket blades that fit. Do a search on gator blades and you will find a lot of discussion on how to make adapter bushings. Gator blades have mixed reviews.
You can find stock blades at online sources (TractorSmart, Messicks, Carver, etc.).
I am actually in Fulshear, so not too far from Needville!
My problem is that they do give a satisfying clunk when they are dry, but when wet, they sure mix with grass and make a great cement under the deck!
/ Replacement Mower Blades for BX #9
Sharpening them yourself isn't that bad. I have mulching blades on my 60" deck and I've sharpened them once a year for 10 years now. You can find lots of info on sharpening in the archives. Our pocket gophers push up big mounds of the clay, as well as rocks that are down in the clay. Though I try to kick them down before mowing, the blades still hit lots of rocks.
Basically, You need a wooden block to stop the blade and a big wrench, or at least a cheater pipe to extend the length, to get the blades off. You need a bench vice (preferably bolted down) to hold the blades, and an angle grinder. I got my vice and grinder from Harbor Freight for about $20 each. They come in handy for lots of other stuff too. A cutoff disc on an angle grinder cuts through metal much easier than a hacksaw blade on a reciprocating saw.
I won't go into grinding technique very much here. You need not to overheat the metal, though, so you don't distemper it. Wear eye protection. Be aware that grinding perpendicularly to the blade leaves a concave cut (can't remember the big vocab word for that right off); this can be minimized by turning the grinder and somewhat grinding with the planar (flat) side of the grinding disc. the more chamfered/beveled the edge, the thinner and sharper the metal, BUT the shorter the time it will stay sharp. New blades have a crisp edge but are around 80 degrees. You don't want an edge like a knife. I sharpen mine to about 40 degrees.
It's important to insure that the blade is balanced. Unbalanced blades can cause excessive vibration when the MMM runs. There are fancy gadgets for this task, but I just hang the blade on a little finish nail I have sticking out from a wooden storage shelf and make sure the hole is centered on the nail. If one side drops down, I just grind a little more off that side until the blade balances.
Clean the deck while the blades are off. When you put the blades back on, torque appropriately. Make sure to hit all the zerks with a grease gun. Check the belt.
Remember-tons more info in the archives-use the search function. Hope this helps.
/ Replacement Mower Blades for BX #10
Bringing this back up to the top once again. Has anyone found good direct replacement gator blades for the 60 inch deck ? Not interested in using washers, must have the 11/16th inch hole.
/ Replacement Mower Blades for BX #12
Frankly, rather than resurrect a 15-year-old plus thread, it would probably make sense in the future to just post the new question as a new thread…
Reason being when someone sees it is such an old thread, they may not bother to go to the end and see what the most recent post is
Just a bit of fatherly advice…😂😂😂
UNUSED JCT QUADRUPLE TINE BALE SPEAR (A65055)
UNUSED JCT...
2018 Ford F-150 Crew Cab Pickup Truck (A64556)
2018 Ford F-150...
Wooden Table (A64557)
215620 (A65053)
215620 (A65053)
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A65055)
UNUSED RAYTREE...
