Lime-- mud relief? or urban legand?
   / Lime-- mud relief? or urban legand? #21
We had 2- 8 gauge industrial shotguns. They shot a quarter pound of lead. It was not uncommon to go through 4 or 5 cases at a time.(250 to a case) One shooting one loading,you could shoot out a lot of lead. If the chemistry was not exactly right it would form rings in the kiln which was 12 foot in dia. and 390 feet long,we had 3 kilns. The rings had to be shot out to allow the product to free fall as the kiln turned. I have seen balls in the kiln that formed in the back and were at least 8 foot in dia. We had to bust them up before they dropped in the cooler. Sometimes it seemed like we shot 2 or3 times a shift and sometimes we went weeks with out shooting. Our kilns were cement kilns,the lime was made into cement. The temp was different at certain parts of the kiln,over 3000 degrees,in the middle,about 1200 where it dropped in the cooler. The exhaust temps were lowered by spray water to as low as 400 degrees.
So, does this mean that the resulting cement is contaminated with lead pellets?
FWIW, my brother used to (and maybe still does) sprinkle lime in his outhouse to help keep down the smell and flies. I don't know whether it turns excrement to concrete, and I'm not interested in delving into it further.
BOB
   / Lime-- mud relief? or urban legand? #22
Now for some reading, and maybe another item for the old bag o' tricks!
@wampum: On account of the heat and noise I figured it was the closest thing to **** on Earth. QUOTE]
I would have voted for a steel or lead refinery (both of which I have toured), but maybe a lime kiln would qualify, too.
BOB
   / Lime-- mud relief? or urban legand? #23
In that intense heat most of the lead is destroyed. But I imagine that there are trace elements,as in anything. The amount shot was several minutes a day,and sometimes you did not shoot for weeks. Making about 185 to 200 tons an hour probably reduced what was left of the lead to a trace element. If not I am sure the EPA would have fined us for it.
   / Lime-- mud relief? or urban legand? #24
WE use lime all the time to get trucks out of the mud and I mean buried in mud. Way cheaper than tow truck and awhole lot easier just toss a few shovels on the tires and ground and watch your truck crawl out.:thumbsup:
   / Lime-- mud relief? or urban legand? #25
This is definitely an interesting thread. I have a rock driveway that really needed some large base rock but instead has 4 inches of fine rock from a local asphault plant. Approx 1/2 of the drive has base the other half I added does not. Worked great this summer but the wet winter and large trucks (building a house) has made the non-base rock area soft. Can I add lime to firm it up? Sounds like I could just spread it on top and let the tires push it to the mud....
   / Lime-- mud relief? or urban legand? #26
I have a stable and the area outside the stable doors is nothing but mud when it rains or snow melts. My best solution is probably having someone dig it up and put down a geo-textile material, the proper gravel, rocks, etc. in and then put material down like what is in an arena.
When it is really wet, the horse's hooves go down about 8" in the mud. I am sure it is uncomfortable for them.
But, after seeing this thread, would it be advisable to use many bags of lime to see if it could be dried up some? I had never heard of doing this before and I don't know if horse hooves walking through lime would be dangerous to the hooves or not.
Just curious.
Bob
   / Lime-- mud relief? or urban legand? #27
Lime may help for the short term but from my experience with a drive you are talking long term and you need more gravel. When I built, in the country, the first time gravel was one of the bigger surprises. The first couple of years it seemed like someone was stealing it during the night. After adding more than expected the first 3 years to build the proper base it has lasted well without additional gravel.
MarkV
Bob,
I can't say for sure--
but I did find this during my research..
Mud Fever: The Animal Files
when I went back to find that link I found this:
Home
hmm..
I wonder how much it costs...
J
   / Lime-- mud relief? or urban legand? #29
RadarTech: Thanks very much. I am going to contact the stable grid place and get a quote for their product. I am sure it will not be cheap, but if it stops the mud, it will be worth it.
Also, I will be on the alert for the mud problems. I had no idea it could be so destructive. But, it does not surprise me.
Bob
   / Lime-- mud relief? or urban legand? #30
Bob
Bob, please let us know how that works out for you. It looks like an interesting concept. Good luck!
2013 COACHMEN CATALINA TRAVEL TRAILER (A50854)
2013 COACHMEN...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2014 MACK GU (GRANITE) (A50854)
2014 MACK GU...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
197637 (A50459)
197637 (A50459)
