Lime-- mud relief? or urban legand?
   / Lime-- mud relief? or urban legand? #11
I had never seen lime used for livestock lots until I moved to where I presently live. The neighbor up the road had me use a box blade to spread lime in barn lot where he runs horses and cattle. He says that there is no gravel base under the lime and when he cleans the lot he is not spreading rock with the manure. We often do chores for him and his wife when they are gone and I can honestly say that his lots seem to have a bottom in them when it is really wet but they are sloppy 2 to 3 inches deep. His lots are on top of a hill with very little clay.
   / Lime-- mud relief? or urban legand? #12
Interesting thread, I wonder what kind of affect the lime would have on grass growing after it has been spread?
   / Lime-- mud relief? or urban legand? #13
I googled lime stabilization. Here's what it said:
Abstract
Clay soil can be stabilized by the addition of small percentages, by weight, of lime, thereby enhancing many of the engineering properties of the soil and producing an improved construction material. In order to illustrate such improvements, three of the most frequently occurring minerals in clay deposits, namely, kaolinite, montmorillonite and quartz were subjected to a series of tests. As lime stabilization is most often used in relation to road construction, the tests were chosen with this in mind. Till and laminated clay were treated in similar fashion. With the addition of lime, the plasticity of montmorillonite was reduced whilst that of kaolinite and quartz was increased somewhat. However, the addition of lime to the till had little influence on its plasticity but a significant reduction occurred in that of the laminated clay. All materials experienced an increase in their optimum moisture content and a decrease in their maximum dry density, as well as enhanced California bearing ratio, on addition of lime. Some notable increases in strength and Young's Modulus occurred in these materials when they were treated with lime. Length of time curing and temperature at which curing took place had an important influence on the amount of strength developed.
Now, can someone put it in englich? :confused:
   / Lime-- mud relief? or urban legand? #16
So, when you add lime to mud, you're making...concrete? It makes sense that it would harden up and not be so "muddy" anymore. :D
I'm prety sure that lime is a strong alkali, and will make soil basic (pH > 7). Some plants like alkali in the soil, others can't stand it. I'd do some reasearch on this aspect of lime treatment before I went and spread a bunch in my yard.
   / Lime-- mud relief? or urban legand? #17
They sell ag-lime by the bag full. It's used in barnyards etc. to harden the areas it's spread upon.
   / Lime-- mud relief? or urban legand? #18
Hmm- If I spread lime on a claylike soil that tractor drives on, would it help prevent sinking and making ruts every spring and fall ?
   / Lime-- mud relief? or urban legand? #19
yes lime is basic so it will react with acid in the soil.
   / Lime-- mud relief? or urban legand? #20
There's a story from the village where I grew up...where a fellow was left to look after the lime kiln at the local pulp mill but wasn't vigilant...such a mess was made that they had to shut the kiln down and clean it out...that man was forever known as "Lumpy"
1999 Freightliner FL70 Truck, VIN # 1FV6HJAA0XHB19718 (A44391)
1999 Freightliner...
2016 Ford F-250 4x4 Ext. Cab Pickup Truck (A44572)
2016 Ford F-250...
2000 Sterling L7501 Petersen RL3 Rear Mount Grapple Truck (A42742)
2000 Sterling...
2016 Dodge Charger Sedan (A44572)
2016 Dodge Charger...
2018 RAM 1500 (A45333)
2012 TRANSCRAFT/WABASH 48’X102” FLATBED CHEMICAL TRAILER (A45046)
2012...
