Foot Treadle
/ Foot Treadle #61
My error. My 1445 does use a Napa 1759. I just went and checked.
Sorry for the confusion.
All the best,
Peter
My 1845 takes the Napa 1759 (Wix 51759) which I think is a physically larger filter than the 1551. I would have thought the 1445 and 1845 would use the same hydro filter.
/ Foot Treadle #62
coolconnection did they give you a cost estimate on the repair or replacement pump? In my pt I have rotella hydraulic oil in mine now in the hydraulics, it seems to do the job. I don't know if that was a good choice or a bad choice, but it hasn't caused any adverse effects yet.
Well on the receipt it said for a new pump covered under warranty for the PT425 is $1,985.40 so I am really glad for warranty repair. So now I really understand why it is so important to take care of the hydraulic system. I will really watch what I do with it now.
/ Foot Treadle #63
Not to talk anyone out of taking care of their tractor...but...
What you describe sounds more like either a defect in assembly at the pump factory, or more likely to my mind, a part that had a defect within it and failed.
All the best,
Peter
/ Foot Treadle #64
Ponytug, I think you are right. I guessing a hairline crack in something internally at the factory and at 73 hours it couldn't handle the stress and it became toast. But I'm still going to maintain my system well. I've read a few articles and it is not uncommon to get 15,000 to 20,000 hours out of these pumps.
/ Foot Treadle #65
About he only thing you can do, is keep the fluid below 200 degrees, and change the input filter often.
Just curious if you had ever tried to push or tow the PT?
/ Foot Treadle #66
Nope, never pushed or towed it. It has always worked before. I got the pump back yesterday and finished putting it in today. So if I did everything right it should be just fine.
/ Foot Treadle #67
I am assuming that you filled the pump with oil, and bled out all the air.
/ Foot Treadle #68
Oh yeah, don't want to have to go through this again. All that stuff holds a lot of oil and air. I didn't think it would ever quit burping. Terry told me how to do the reinstall and get the air out like I was changing the filter which it got a new one as well. It wasn't to bad, just didn't want to overheat my starter so I waited a few minutes in between cycles. The only thing I haven't done yet is actually fire it up. After it quits snowing tomorrow it will get a work out.
/ Foot Treadle #69
Having the price of what it would have cost you had it not been under warranty is good to know for those of us that the warranty has already ran out. Just curious did he tell you of a way to manually fill the pump up before trying to purge the air out, so the pump wouldn't start out dry?
/ Foot Treadle #70
No, but the pump was shipped with oil already in it with caps on all the connectors. Remove a cap and hook up an oil line. A lot of if not all the oil still leaked out of the pump but Terry told me to bleed the air out of it like you do when you change the hydraulic filter. I did the air bleeding many times just to be sure there wasn't any air left in the pump. Now I got my battery on the charger just to be sure it will start tomorrow.
/ Foot Treadle #72
5AM in LA.... So did it run like a top?
Oh yeah, runs great. It is so nice having it back in operation. I was lucky that the 12" of snow we were suppose to get last weekend skipped us so I made do with a shovel but I had to push 5" of snow this morning and it did awesome. I think it might even be torquier than the last motor. Before the rebuild the motor just always seemed to want to die before the tires spun this one I have to be careful it just keeps going. I asked Power-Trac if I was getting a new pump, rebuild my old pump or a used pump. They said yes to all three, hmmm it must have been pretty bad inside that thing. Hey, it pushes the snow out of the way so it works great.
/ Foot Treadle #73
Just a note; my motors have buried in the owners manual the admonition to not run them over 50% power for the first 15 hours... I don't know if it applies to pumps, but it probably wouldn't hurt to take it easy as things break in.
All the best,
Peter
P.S. Did I mention I didn't find out about it until after 15 hours had gone by?
/ Foot Treadle #74
The fact you have an owners manual at all speaks volumes. I have one, it is a parts catalog of sorts. And a half page of "maintenance" suggestions
/ Foot Treadle #75
Thanks I will keep that in mind for the next 14 hours. I didn't even have it at full throttle, I wasn't working it to hard. I didn't get an owners manual either, I got a parts catalog to like Wooklandfarms did.
/ Foot Treadle #76
I didn't get a full blown owners manual from PT either. I just blew a motor seal at 3.5 hours or so, and decided to match my motors to find the manufacturer, and then read their owners manual.
All the best,
Peter
2017 Chevy Malibu (A61574)
2017 Chevy Malibu...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
iDrive TDS-2010H...
2012 VANTAGE TRAILER PNEUMATIC CEMENT TRANSPORT TRAILER (A63569)
2012 VANTAGE...
McLaughlin Boring Machine (A64047)
McLaughlin Boring...
35in AIM Tooth Excavator Bucket (A64194)
35in AIM Tooth...
