Foot Treadle
/ Foot Treadle #21
Well, I should find out the damage early next week. They felt confident about repairing it so lets hope that is all it is. I thought about debris in the system but nothing came out in the hoses upon disconnecting them. It all happened pretty fast but I will talk to Terry about crap in the lines. I feel better about it all now but I hope I don't have to replace the pump. It is just over two months out of warranty, just my luck. That tractor is a snow pusher. I have piles of snow over 6 feet high around here. I just hope I don't get to much snow before I get it all put back together. You know after tearing the thing apart, it really wasn't as hard as I thought it would be. I think I only took out 9 bolts total and I was right down to the main pump.
/ Foot Treadle #22
jj is right on about checking with pt in Tazewell to see how would be best to make sure there isn't anything else in the oil system and the best way to clean it up. hopefully you don't have another problem in that system that might have had a piece break lose and go through the pump that caused the problem. Hope the best for you at the lowest cost possible.
/ Foot Treadle #23
Thanks, I hope this doesn't turn into a nightmare. I will be so ticked off if it does.
/ Foot Treadle #24
When I first bought my PT422, I was told that if I ever go into the wheel motor circuit, I should flush and filter the hydraulics with a 3 micron filter.
/ Foot Treadle #25
Bob Rip since you mentioned it, I seem to remember being told that to or read it one. I think I would change the filter when I got it back together and then change it again after I had run it for a while, I wouldn't wait on the 50 hour schedule on that change and I am kind of a curious guy, I would cut the filter open and check what was or is in it.
/ Foot Treadle #26
The built in filter is only 10 microns. They want a much finer filter after this or similar incident.
/ Foot Treadle #27
Bob Rip did you understand them to mean to run a 3 micron all the time from then on or just to run it for a short period of time to recirculate the oil and fine filter out the contaminants and then go back to the 10 micron? I thought it was just for a short period of time, and I have talked with others that have varying opinions on that. When I lost my wheel unit I just changed the filter and worked it for a few hours and then changed the filter again and then went back to the scheduled maintenance program. I didn't use a 3 micron filter I just used the regular filter, I wouldn't advise anyone else to do that, that is just what I did.
/ Foot Treadle #28
Would running it at idle for a few hours without driving the tractor, possibly working the PTO and loader be a god idea?
Ken
/ Foot Treadle #29
Ideally, you'd flush the lines first, and then block up the tractor and and slowly flush the lines. I would put a really strong magnet on the filter. You want to get anything that you can possibly suck out of the oil.
I'm wondering if PT has in mind replacing the 10 micron with a 3 micron, or whether they envision a 3 micron in the pressurized wheel motor circuit. (which is where I would put it, but remember to only go one direction!) IF you replace the main filter, go easy on the PT when it is cold. You will be pulling a heck of a pressure drop across the filter, and it will be prone to degassing and cavitation. So, low engine speeds until the oil is warm/hot. Preheat the oil, if you can.
I don't think that running it at idle isn't going to sweep the debris, if there is any, out of the lines. Even if it sweeps some out, when you crank up the speed, more will get flushed out.
I am curious what the opinions are of people who deal with this regularly; does one strip the motors? does one flush the motors with clean oil?
All the best,
Peter
Ken
/ Foot Treadle #30
The filter installation used by PT is a compromise--it is generally undesirable to have a filter on the supply line because as the filter loads it increases the potential for cavitation but cleanliness of supplied oil is essential with positive displacement pumps such as the variable displacement pump used by PT. So the PT compromise is to install a 10 micron filter on the supply line for the variable displacement pump (which includes the charge pump) and to recommend very frequent filter changes to minimize to possibility that the filter loads up and causes cavitation.
I would NOT install a 3 micron filter in place of the 10 micron filter because of the likelihood that cavitation would result and damage the pump. If a clean up is necessary I think a filter cart or other filter arrangement should be used.
/ Foot Treadle #31
It is just for a short time with the 3 micron and then go back to the 10. You need to talk to Terry at PT to get more details. I think a lot of people have done what you did, but I expect PT knows best. It does seem strange to me to only use the 3 micron for a short time, but I am very far from an expert in this.
/ Foot Treadle #32
The failure that I had was different than coolconnections, but the 3 micron filter would filter out any thing that would hurt his pumps and other components in his system. I would want my filter on the suction side to catch anything that might be in the system before it went through my pumps as they are expensive [variable volume]. As far as cavitation of the pumps that is not a good sound but you know to check your oil level, check for oil leaks, and change the filter I would rather hear cavitation than klunk klunk then no movement.
/ Foot Treadle #33
Just hope that the density of the particles is more that the weight of the hyd fluid, so it will settle to the bottom of the tank. The fluid used by the PTO pump and the steering is not directly filtered. The tram input filter will eventually filter all the fluid, but by that time, some of the crud will pass through the pumps mentioned. There might be something to adding a return filter to the tank to keep crud out. I guess the large hyd tanks that the PT's have, help settle out most crud before it is picked up by the other pumps.
/ Foot Treadle #34
I did drain all the oil out of the PT before disconnecting the hydraulic lines and pump. How difficult is it if I take the rectangle lid off the oil reservoir and have it seal again. What is involved to keep it from leaking once reattached? Do I need some kind of sealing agent? This could be a good time to clean it out. I bought a fuel shut off valve for it and new fuel lines so when I put everything back together it will be all done. Thanks guys, I am reading this thread daily just to keep up.
/ Foot Treadle #35
My cover has always leaked a little on steep slopes. The main worry is that means water etc can leak in. I tried the RTV gasket material and i can not remember if it was cork or rubber that i also tried - it was very hard to find anything big enough locally so i used what was available. The rubber ones on the magnets have never leaked. One threaded bolt hole for the cover was stripped when i got it (might have to resort to a helicoil or oversized bolt).
I think maybe the vent on the fill cap was plugged and that is why the RTV gasket failed. I installed a desiccant breather cap when i tried the second material. I want to make a new cover and will try again then.
Ken
/ Foot Treadle #36
Does anyone know if the tram pump for a PT 425 is a Bondioli NT10. I was doing a search and also contacted Bondioli and found that there is a dealer not to far from me. If I have to pay for a new pump I want a good one and under warranty. I read PT warranty says only 30 days on replacement parts. I am just being prepared for the worst but hoping for the best. PT took off the manufacturer name tag that was riveted to the pump. Now why would they do that, that is just not right. I was looking up the nt10 tram pump and it has several choices. Oh well just being overly prepared.
/ Foot Treadle #37
permatex will seal it I believe unless maybe if it is painted under the cover, then I don't know. Now would be a good time to add anything you might want to the lid while you got it off. I remember one of the posters put a screw on cap instead of the cap that we presently have, and some have mentioned putting an oil level indicator on theirs, or a temp gauge.
/ Foot Treadle #39
wow. Nice job. I wouldn't have thought about having two seperate magnet columns. How close to the bottom of the tank do the magnets go?
What kind of disicant breather did you end up with? Is the idea that when the oil heats up, the water had to leave the tank somehow? And then when it cools and contracts, air has to go back into the tank ... probably being moisture with it in the summer?
/ Foot Treadle #40
I would have to go and measure the depth of the tank to see how deep the tank is but they must come reasonably close since they are over 10" long. Some people had some interesting ways to try to accomplish the same thing in this thread:
http://www.tractorbynet.com/forums/power-trac/102333-filter-cart-tank-magnets-etc.html
Yes, as you use the tractor, it heats up the oil which expands thus venting air from the tank. As it cools, the oil contracts sucking in air which also contains water. The desiccant breather takes the moisture out of the air as in enters the tank. When venting, the hot air removes moisture from the desiccant, venting the moisture to the outside.
These are the desiccant breathers I am using:
TRAP Breather
Has an LED that lights up if the desiccant is no longer any good.
Ken
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
2022 EZ-GO ELITE...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
207274 (A52708)
207274 (A52708)
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
