Tell me about Hinomoto tractors
/ Tell me about Hinomoto tractors #21
Hinomoto was bought by Hitachi. The rumor that Kubota bought them came during a time when Hinomtos were just rebadged Kubotas specifically the NX series. I like the N and C series but have discontinued selling any E models due to the aluminum bell housings and on some models the unsupported cone pivot front axels. Models without the lower brace on the cone cannot handle a loader.
Buck
/ Tell me about Hinomoto tractors #22
I agree and mine will probably be one of them. But I expect in 10 years I'll be too old to play around with them anyway. Last winter I was trying to switvh to Yanmar. Looked for an F or FX24D. Couldn't find one and then the N239 came up on ebay. The rest is history and now I'm back into Hinomotos hot and heavy. I've got an E2604 and an E2804 coming from Japan with a delivery date of 10/28.
Eugene
PS Wayne, it's a funny thing. "Lawn Ornaments" is what my wife has called my tractors from the start.
Hi Eugene:
I am about of buying de E 2604 model. Iエve never had a minitractor before, then i ask for your advice. How it went this tractor with you?. Would you recomend me to buy it?. Are parts available to buy?.
Well, thanks a lot to read my note, hoping to get your answer a big hand from Bolivia.
Homer
/ Tell me about Hinomoto tractors #23
Homer
The E2604 is a good tractor. Nothing has happened to mine
, yet. I put a Bush Hog loader on it and work it hard. Parts are available but you have to know where to look . They're not easy to find, sometimes. So far mine hasn't needed anything, so I don't worry about the parts issue unless it comes up. Hope this helps.
Eugene
/ Tell me about Hinomoto tractors #24
E 14 hinomoto, lift works till it gets warm then drops. After it cools down it works for an hour or so then quits again. Is there a filter in this system, if so where. Is the pump going out? Any thoughts would be appretiated.
/ Tell me about Hinomoto tractors #25
I have a Hinomoto E-21 (The E-14 and the E-21 are from the same product line) and On my machine, there is a fuel filter mounted right under the tank on the left side of the machine (from the operator's station)
/ Tell me about Hinomoto tractors #26
Why stay away from the 2cyl engines?
Found a 2cyl with 120hrs, box scrape and 48" finish mower for 3000
/ Tell me about Hinomoto tractors #27
They are from the late 70's 7 engine partsare becoming obsolete. Don't believe the 120 hours. It is probably a Viet rebuild with the hour meter turned back.
/ Tell me about Hinomoto tractors #28
Can anyone tell me what model of hinimoto this is and the pros and cons of it. Came up for sale cheap. Thinking of looking at it. What is the common problems with this model. Thanks opps the picture did not attach. i'll try again
/ Tell me about Hinomoto tractors #29
Can anyone tell me what model of hinimoto this is and the pros and cons of it. Came up for sale cheap. Thinking of looking at it. What is the common problems with this model. Thanks hinimoto.jpg
/ Tell me about Hinomoto tractors #31
Can anyone tell me what model of hinimoto this is and the pros and cons of it. Came up for sale cheap. Thinking of looking at it. What is the common problems with this model. ThanksView attachment 180640
Looks like a 184 or the like. Not a fan of this model and the loader makes it worse.
Buck
/ Tell me about Hinomoto tractors #32
I have a 1975 Hinomoto E-15.I have owned it for almost 10 years, It works almost every day.The only thing I have ever had to replace was the starter, which I had rebuild local at a very good starter shop.I Have always change the oil and coolants. But My transmission fluid. needs changing and I don't know where the filter is located, Can anyone help?
/ Tell me about Hinomoto tractors #33
Follow the hydraulic lines to the rear of the tractor and remove the bolts. There is a screen inside. Just clean and reinstall the lines.
Eugene
/ Tell me about Hinomoto tractors #35
Hinomoto in my opinion not as good as Kubota or iskeki
/ Tell me about Hinomoto tractors #36
I have a Hinomoto E2002 Farm tractor for sale in Chandler, TX. Only 95 hours with a 4' brush hog. Runs great! Priced at $3500. See pictures at Home Page | Park & Sell | Auto dealership in Chandler, Texas. I have a number to a guy in Vegas who sells parts for these tractors at a good price. Nothing is wrong with this tractor. It has a fresh oil change and cranks right up. Call me at 903-213-5701 if you are in the area and want to see.
/ Tell me about Hinomoto tractors #37
I would like the number of the parts dealer in Vegas. I have a MF 210 with the 1.3L Toyosha 2 cyl. (same as E23). The only parts importer I found has prices that are unbearable.
/ Tell me about Hinomoto tractors #38
Sorry for the late response. His name is Wynn and his number is 866-582-1172. He has all kinds of parts for Hinomoto Tractors. If you know anyone who wants to buy an E2002 Hinomoto Tractor, let me know. I have one with a brush hog and low hours. 903-213-5701
/ Tell me about Hinomoto tractors #39
I have the same lift problem.
, after one hour, the lift will make noise and stop working. After coll down, works again. I also do not know the cause. I think the problem may be in the valve body under the seat
/ Tell me about Hinomoto tractors #40
I have the same problem with my E16. I think the problem may be in my valve body under the seat but that is just a guess
2016 Ford Fusion Sedan (A61569)
2016 Ford Fusion...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2011 Chevrolet Cruze Passenger Car, VIN # 1G1PK5S94B7295110 (A61165)
2011 Chevrolet...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2013 KENWORTH T800 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2013 KENWORTH T800...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
