Additional uses for log splitter,
/ Additional uses for log splitter, #1
BHD
easten Colorado
JD 4020
I got a farm magazine to day and it has a section where they print ideas that can be useful around the farm,
any way for some reason I never thought of multi uses for a log splitter,
one of the ideas was where some one made a head for there log splitter for bending re bar for a project,
and that got me thinking pipe bender, or tubing bender with some type of head, even a horizontal press.
could a oil seed press be made?
or some type of peltizing machine head be made for it?
Oil filter crusher?
and thoughts what other ideas or things have you used or made for attachments, for a splitter,
/ Additional uses for log splitter, #2
tire crusher. crush, turn 1/4 turn repeat then the rim falls out of the tire.
/ Additional uses for log splitter, #3
I've used mine to break tire beads and bend diamond plate for trailer fenders.
/ Additional uses for log splitter, #4
I used to recycle cans. I envisioned some heavy plates and a way to crush shovel fulls of them But never made it past that stage.
/ Additional uses for log splitter, #6
Tag. I'm thinking trash compactor.
/ Additional uses for log splitter, #8
When I made my splitter I made a adapter a few weeks later to use as a shop press.
You can see it sitting on the splitter. Just pull the pin, tilt the cylinder, remove the wedge, install the press adapter.
Chris
some good ideas, thanks, any more?
/ Additional uses for log splitter, #12
I'd like to see some of the tooling dies used for bending ops.
What about pressing bearings etc? like in those shop presses.
JB.
/ Additional uses for log splitter, #13
Since SOME PEOPLE are coming down on water boarding terrorists to get info that might save lives, how about .......... naw that won't ever fly, but it was fun to think about.
Jack
/ Additional uses for log splitter, #15
Wine corker or beer capper:confused3::confused3:
Laminating clamp?
/ Additional uses for log splitter, #16
JB.
I second that idea.
Does anyone have some pictures of their setup?
Thanks,
Clem
/ Additional uses for log splitter, #17
At one time I was going to fab up a fixture so I could compress the springs on my struts. Had used the store bought hook on a threaded rod type before but was just a major pain. Ended up bringing them to a garage to have it done for $10 a piece instead. Still, I think it would work fine, just need to design it so the spring is captured and can't go BOINNNNGGGG! :D
/ Additional uses for log splitter, #18
Giant crossbow cocker!!
/ Additional uses for log splitter, #19
I have a small electric splitter and am amazed how well it works-
I have considered using it like a hydropress used for aircraft parts (I'm an ex-Boeing guy)
using a male (or female) mold on one side of sheet metal and thick rubber on the other to deform complex parts shaped like ashtrays or antique tailights. The male mold can be made from masonite-or even a hard wood, the rubber from multiple layers of innertubing.
/ Additional uses for log splitter, #20
I vote this is the most creative use so far.
I also vote that when you get it built, you let us know so that we can all start ordering obsolete sheet metal parts from you.
5-Pointed Star Metal Decorative Sign (A64557)
5-Pointed Star...
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
2145 (A65055)
2145 (A65055)
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A64556)
2013 Freightliner...
2000 STERLING T/A DAY CAB ROAD TRACTOR (A64278)
2000 STERLING T/A...
