Foot Treadle
/ Foot Treadle #51
Hey, that's a great prognosis. Pretty much all the debris should have been contained in the crankcase for the pump.
Good luck,
Peter
Thanks J_J I read it all. I think I will just keep the standard oil in the system.
BobRip I to have an insulated garage and I don't think it ever gets under 47-50 degrees in the winter. So my PT is not to hard to start in the winter. I called PT today to check on the pump and they told me my "swash coupler broke loose and smashed into the pistons and broke them to". I think that is how they said it, I probably got that wrong. I was also told it was a basket case. It will be finished tomorrow and shipped back to me. Terry told be everything was isolated inside the pump so nothing should be in the lines but I should change the filter to be safe. It was only the 2nd one they have seen broke this way, he said they're a tough little pump (Hmmm mine wasn't). But it will be fixed woohoo. Now I have to put it all back together. Thanks everyone for the help and insight.
/ Foot Treadle #52
Hey, that's better news than we expected. Hope it goes back together easily for you.
/ Foot Treadle #53
coolconnection did they give you a cost estimate on the repair or replacement pump? In my pt I have rotella hydraulic oil in mine now in the hydraulics, it seems to do the job. I don't know if that was a good choice or a bad choice, but it hasn't caused any adverse effects yet.
/ Foot Treadle #54
They put it under warranty repair. I am so glad of that I don't know what it would have cost otherwise. Also I decided after reading many threads on this that I will just stick to the 10w-40 motor oil in my hydraulics.
I know this probably isn't the right thread for this but I have 1 PT filter left. Did any of you find a good filter in the 10 micron range that fits and works well other than the PT filters for a PT 425? I would like to find one locally and the TSC filters I found were around the 25 micron range so I don't want them. If you have found any where did you find them? Any help is appreciated. Thanks
/ Foot Treadle #55
I get mine (1445) at Napa, but I don't know the number for the 425. You might ask Terry.
All the best,
Peter
...I know this probably isn't the right thread for this but I have 1 PT filter left. Did any of you find a good filter in the 10 micron range that fits and works well other than the PT filters for a PT 425? I would like to find one locally and the TSC filters I found were around the 25 micron range so I don't want them. If you have found any where did you find them? Any help is appreciated. Thanks
/ Foot Treadle #56
When I did a search I found the following:
I have found different hydraulic filters are available locally at farm equipment dealers. I am currently using a purolator H32010 filter for the hydraulics, purolator assured me it is a 10 micron that power trac recommends. The original hydr. filter on my power trac 422 was a gresen K22001. I have not been able to find replacement oil filters for the robin engine in my 422 , but I can buy them from a local garden tractor dealer.
Re: Hydraulic Filter replacement [Re: deadstick]
#183577 - 08/13/02 10:03 AM Edit Reply Quote
here it is, sorry for the delay!T
NAPA 1551, make sure it is rated at 10 micron.
/ Foot Treadle #57
Bob- that's the Napa filter that my 1445 uses. Maybe one size does fit all... :)
By the way, the 1551 is a 10 micron filter; the 1553 would be the 30 micron equivalent.
All the best,
Peter
/ Foot Treadle #58
Thanks, I will look some of them up. I just use regular oil filters on my 25 hp Robin engine. I am using a Walmart cheapy. Those cheap filters at Walmart I think are AC Delco or something but I know they are not Frams. I change it every 50 hours religiously. Here are some cross referenced #s I found for the filters: STP S4967, Fram PH4967, fleetguard LF779, wix 51394, AC Delco PF-1220. I talked to a few people and found that there is really no difference in lawn and garden filters to the automotive ones. I have used them for years. I don't want to spend $12 on the same filter I can get elsewhere for $4.
/ Foot Treadle #60
All the best,
Peter
My 1845 takes the Napa 1759 (Wix 51759) which I think is a physically larger filter than the 1551. I would have thought the 1445 and 1845 would use the same hydro filter.
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
2013 MACK GU713 CAB AND CHASSIS (A60736)
2013 MACK GU713...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
skeleton / rock bucket (A56857)
skeleton / rock...
