TC-40D issues - thanks, guys!!
   / TC-40D issues - thanks, guys!! #1
dubldee
I have a TC-40D that has had just about every issue that is common to the Boomers. I just want to give a shout out to those who helped me:
Overfull crankcase - this one really scared me, but JC-Jetro and Jinman put me on the right track to replace the hydraulic pump seals. Problem solved.
No crank, no start - search function really helped here, as i had the dreaded PTO light on, and again, Jinman put me on the right track by replacing the fuse with a self-resetting c.b. (which I finally bought after replacing the fuse 3 times).
Cold running TC-40D. - - This one has puzzled me since I bought the tractor. I finally ran across the applicable threads, vice-gripped the bypass hose to test the theory, and voila!, lil blue started warming up like she should in 45 degree weather. Shutoff valve now installed. Thanks, tpaulsen and again Jinman.
No glow plug on starting - intermittant glow plug light illumination while running........... a search turned up PineRidge's comments, among others, so I ordered the timer relay from Messick's and (of course) fixed the problem.
It's amazing how much money I have saved in repairs from the above posters' professional and freely given advice and counsel. Thanks, guys, and thanks, TBN!
   / TC-40D issues - thanks, guys!! #3
Thanks dubldee!:) The best way you can pay us back is by passing the info on to others. If you read a post from somebody having a similar problem, just tell them what you've learned. The nice thing about good advice is that nobody has a patent on it. You are free to use and share it as needed.;)
   / TC-40D issues - thanks, guys!! #4
It is also important for the person asking the question to reply with the final solution. A large percentage of this board's knowledge is based on vast collections of anecdotal solutions - if the "case is closed" it contributes to that knowledge - while those threads lacking the "rest of the story" will only be theoretical exercises...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2006 Nissan Murano AWD SUV (A59231)
2006 Nissan Murano...
2007 KUBOTA KX121-3 SUPER SERIES EXCAVATOR (A60429)
2007 KUBOTA...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2004 JOHN DEERE 650H LGP CRAWLER DOZER (A60429)
2004 JOHN DEERE...
