What motor for snowblower chute rotation?
/ What motor for snowblower chute rotation? #1
GPintheMitten
Elite Member
Flushing, Michigan
Kubota B2620 with BH65 backhoe, Ford 2N
I don't have hydraulic remotes right now. Maybe I'll add that later during my fel build. So in the meantime, I want to convert my manual chute rotator to electric.
I've read some of the threads about this. My question is, about what motor to use? I'll probably use a power window motor but I want one that will handle the job. Any advice on how to determine size of motor that will be a good fit?
My current setup uses the hand crank with a wire wrapped around the chute. So I'll probably just try to fab a connection directly from a modified crank to the motor shaft if I can manage that.
Suggestions appreciated (except for making it hydraulic).
/ What motor for snowblower chute rotation? #2
You would be better off buying a small 12 volt winch to do the job.
/ What motor for snowblower chute rotation? #3
Take a quick look in my post about a new way for electric deflector on snowblower and you'll see that I use a small electric winch to turn my chute and it's using the old cable system.Larry:D
/ What motor for snowblower chute rotation? #4
Massey driver, I like that.
I wondered if that was what you had for the chute rotation. I'll take another look at the pic. I might use the winch suggestion for the chute rotation.
Thanks LAWALLSTRACTOR, and massey driver.
P.S. I wasn't going to do the deflector automation but your idea is a good one. I might do that as well.
/ What motor for snowblower chute rotation? #6
One idea I had but didn't try was to use a garage door spring (or appropriate one) to hold the chute to one side.Then use the winch single line to pull it the other way so it would be a simple setup and constant pull on it. I opted to try the windshield wiper motor first and have Had good luck with it for a few years. (mine is stored inside) So the ice and freezing doesn't seem to be a factor
/ What motor for snowblower chute rotation? #7
Why not just use a linear actuator? I can't imagine you'd need all that powerful of one to move your chute. Hook it up the same way the hydraulic version works only replace the cylinder with the linear actuator.
Thanks for all ideas. I'll keep checking back. Great forum.
Right now I'm favoring using the winch idea.
/ What motor for snowblower chute rotation? #9
I too for linear actuator. To me, that would be the easiest to mount, avoiding gears and cables, just welding, or bolting up a couple brackets to mount it to. You'll just be limited to rotation. A window motor seems like the most compact, and with some cable would allow the most amount of rotation.
/ What motor for snowblower chute rotation? #10
Last time I checked linear actuators were fairly expensive, things could've changed though.
/ What motor for snowblower chute rotation? #11
The other problem I see with linear actuators (beside the very limited rotation you'd get from one) is that typically they are VERY slow-when the wind changes and the snow is blowing on you, you want that chute to turn NOW!:eek: The deflector is less critical and would be a good candidate for a linear actuator.
/ What motor for snowblower chute rotation? #12
I don't see how the rotation would be limited if you rig it up in the same manner as a hydraulic cylinder...its basically the same thing from a geometric standpoint. I have one on my blower chuteand the speed is no different from that of a hydraulic cylinder. On my first attempt i used a l/a that was rated at 120 lbs pushing power...it would turn the chute but it was slow and i could hold it back by grabbing it. In the end I used one with 500 lbs push and it works great.
/ What motor for snowblower chute rotation? #13
No one said it was cheap... Looking around on surplus center, a 500lb L/A would be around 180-200 dollars. A similar hydraulic cylinder would be easily half that cost. Though, if you don't have remotes, buying a hydraulic cylinder would be a pretty poor choice. Just thought I'd throw out the option.
Thanks for all the advice guys but I now know what I'm going to do. I'm going with the winch motor for the chute rotation and possibly also the window power motor for deflector.
I'll post pics when I get it a going.
/ What motor for snowblower chute rotation? #15
/ What motor for snowblower chute rotation? #17
I tried two different motors on mine. The first was too small when things iced up, the second (a Lucas starter motor) was too fast and tore things up. Finally found a hydraulic motor in the scrap heap, but failing that you can get a small winch for under $100....
2012 Ford F-350 4x4 Ext. Cab Rugby HR-520 Mason Dump Truck (A59230)
2012 Ford F-350...
2014 COTTRELL CAR HAULER TRAILER (A59904)
2014 COTTRELL CAR...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A60352)
2013 Chevrolet...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
