4320 Cab Radio Install
/ 4320 Cab Radio Install #1
1speedy77
Purchased a 2009 John Deere 4320 with cab,but it did not come with a radio.Can somebody tell me how to install one ,so I can do it myself.
/ 4320 Cab Radio Install #3
Just had a buddy install a new radio on my 4320. You must remove the roof. It is not hard (13 nuts) but you will need some help to lift the roof without messing up the seal. When replacing the roof just be sure you set the roof down w/o sliding to insure a good seal. A/C will not work right without a proper seal. Don't know if speakers come without a factory radio. I replaced mine with AM/FM/CD/Satellite. As I said it is not a hard job. You can do it...
/ 4320 Cab Radio Install #4
.....When replacing the roof just be sure you set the roof down w/o sliding to insure a good seal. A/C will not work right without a proper seal.
Ditto...... Several of us folks have had to deal with roof seals leaking after having the roof off to install radio and speakers. Two people are absolutely needed to remove and install the roof. You must lift straight up to remove and straight down to install. Radio install is not difficult. Good luck.
/ 4320 Cab Radio Install #6
I removed mine with 2 people and the seals were already torn as there was an issue with those seals from the factory on the 3x20 series.
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
2022 EZ-GO ELITE...
2001 GMC C7500 Fuel Truck (A62613)
2001 GMC C7500...
Fuel Tank & Air Compressor (A64127)
Fuel Tank & Air...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
