Solar battery tender?
/ Solar battery tender? #1
Casco1
Gold Member
New England
Kubota L series
My tractor its for weeks at a time 150 miles from home in a garage with a great eastern exposure. I've seen ads on Harbor Freight and Northern Tool for solar panels that put out low wattage power. Has anyone used one of these to build a battery tender to keep a battery charged?
I would appreciate any opinions or ideas on this subject.
/ Solar battery tender? #3
My tractor its for weeks at a time 150 miles from home in a garage with a great eastern exposure.......
Wouldnt southern exposure give you more useable hours of sunshine on the panel (s) ?????
It seems to me- eastern exposure would only provide sunrise to mid morning charge on the panel(s)- at best.
/ Solar battery tender? #6
I have a solar battery charger which maintains a deep cycle battery to operate the hydraulic pump on my boat hoist. It gets a good exposure to the sun and keeps the battery charged all spring/summer/fall. Works like a champ. I think the pannel is only about 12" x 16".
/ Solar battery tender? #7
We use solar power to charge the storage batteries on our RR signal locations and the guys have to go out and pull the snow off of them on occasion. If you are away from your area very long your panels may become ineffective. They work great in the none winter months and we're talking about some big batteries.
/ Solar battery tender? #8
I have a Case 450 crawler that sits for months at a time at my woodlot. I used to have problems with batteries not lasting long (2 to 4 years), and this takes a big, expensive battery. About 6 or 7 years ago, when I installed another new battery, I also installed a Pulse-Tech desulphator and then, about a year later I connected a 5-watt solar panel to the battery. Just yesterday that 6 - 7 year old battery spun over that little diesel like nothing, and it hadn't been started for about 3 months. I'm very satisfied with this setup.
/ Solar battery tender? #9
The best thing to do with snow is put the panels in a strictly vertical position so that they don't accumulate any snow. Direct light, and incident light from the snow are more than enought to generate charging current. I have two 15 watt panels keeping my fencer feisty all year round.
CAUTION: Unless it says otherwise, a solar panel should not be connected directly to a battery. I will discharge at night, and overcharge during the day. Make sure that you do or don't need a charge controller with whatever panel you buy.
/ Solar battery tender? #10
I have the one from Northern Tool - paid 19.99 and I think its on sale either now or soon for only 16.99. I have had amazing results. My tractor used to take a lot of crank to turn over, this keeps the battery topped off great and I can fire it up in no time. For under 20 bucks and no other costs its great. Also, the one from Northern has cigarette adapter and battery terminal clips - I use the clips (obviously) and the wire to the panel has a detach so when I need the tractor I just unplug it and dont have to unclip it from the battery. I just leave the inch or so hanging out from where the battery is because the battery is behind a cumbersome protective panel. I am 100% pleased.
/ Solar battery tender? #11
Also, the $20 one from Northern Tool has protection against reverse current draining the battery and it does not require a charge controller so it also will not overcharge... I think at max it generates 1.8 watts, which is almost nothing, but enough to keep a decent battery topped off.
/ Solar battery tender? #12
The first question I have is how long is it between uses? A battery of any reasonable condition should last for a couple of months between uses. This assumes that it is fully charged when last used and there are no loads such as immobilises.
I am not suggesting that it is a waste of time, just that it may not be necessary if only a couple of weeks between uses.
weedpharma
Thanks for all the feedback
/ Solar battery tender? #14
You're probably trying to solve a problem that you don't really have. A few weeks sitting is no big deal for a battery. If you find it going flat between uses, then you should suspect the battery is going bad. A relatively healthy battery should be able to sit idle for quite some time without discharging so much that it won't start. Once the engine is going the charging system should top it back up.
/ Solar battery tender? #15
For $15-$20 get a 1 - 2 watt solar panel mounted on the south wall or in a southern window and connect it to the battery for the winter.
All the new panels will not drain your battery at night and the limited wattage will not overcharge your battery.
I have Two on my dozer (2 huge batterys), one on my dump truck, and one on my TLB. Only get to my property a few times during the winter and everything is in great shape in the spring.
Best $50 I ever spent.
/ Solar battery tender? #16
My parents use one of these on their RV. The trailer sits for minths at a time and always has a good battery. They bought theirs at a large dept/hardware store chain. Even in winter when its well below zero it works to maintain their battery.
Iranch High-End Tricycle (A64119)
Iranch High-End...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
UNUSED 2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
2006 Heil DOT 407 Aluminum 9,000 Gallon Ethanol T/A Tanker Trailer (A64194)
2006 Heil DOT 407...
