4X4 engaged on dry pavement
/ 4X4 engaged on dry pavement #1
chinadill
How long can you run a RTV 900 in four wheel drive on dry pavement before you damage or shorten the life of the machine?
/ 4X4 engaged on dry pavement #2
Why would you want to do that on a constant basis?....I would think you'd be replacing tires before hard parts...But it aint good to do all the time. I run mine in 4wd on dry pavement between driveways sometimes, but if I'm making hard turns I turn the 4WD and Diff lock off to save the tires.
The wife jumped in the rtv and left it in four wheel drive. She drove down to the barn which is a half mile of pavement. I am not sure this is the first time.
/ 4X4 engaged on dry pavement #4
Should take it, no problem.
Prolly has seen rougher times, and not by her. :)
/ 4X4 engaged on dry pavement #5
If that's it...You're good to go...Forget about it.
/ 4X4 engaged on dry pavement #7
Nope, not a big deal. it happens. Other than some tire wear (so little you wont tell) I doubt it will even phase it in the least
Hey guys thanks for the help!
/ 4X4 engaged on dry pavement #9
the rtv has a limited slip front end and if i'm not mistakin it also has a rearend unlocker right? if so your good to go the rear end being locked is whats gonna really kill them front tires. now if your front had a diferential lock on it then you would have some tire problems.
/ 4X4 engaged on dry pavement #10
our old ('99) yamaha kodiak is full time 4wd, its really hard to drive on pavement and shows more wear on front tires even though we try to keep it on soft surfaces.
/ 4X4 engaged on dry pavement #11
You canb run that Kubota in 4wd all the time and it's not an issue. It will turn less sharp and wear the tires a little quicker but mechanically will not be an issue. Most ATV's and SxS's (Yamaha Rhino, Polaris Rzr, etc) are the same way but have more issue due to the locked rear end.
/ 4X4 engaged on dry pavement #12
We use RTV's at work to plow snow. Most of the time during the winter is spent in 4x4 on pavement. There have been no problems yet with the 900's having 2200+ hours and the 1100 only has 100 or so hours.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
1986 CATERPILLAR D4H HI-TRACK CRAWLER DOZER (A64279)
1986 CATERPILLAR...
Caterpillar D7G Tractor Service and Parts Manuals (A63117)
Caterpillar D7G...
Freightliner Columbia (A63689)
Freightliner...
2020 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61572)
2020 Toro...
