4X4 engaged on dry pavement
/ 4X4 engaged on dry pavement #1
chinadill
How long can you run a RTV 900 in four wheel drive on dry pavement before you damage or shorten the life of the machine?
/ 4X4 engaged on dry pavement #2
Why would you want to do that on a constant basis?....I would think you'd be replacing tires before hard parts...But it aint good to do all the time. I run mine in 4wd on dry pavement between driveways sometimes, but if I'm making hard turns I turn the 4WD and Diff lock off to save the tires.
The wife jumped in the rtv and left it in four wheel drive. She drove down to the barn which is a half mile of pavement. I am not sure this is the first time.
/ 4X4 engaged on dry pavement #4
Should take it, no problem.
Prolly has seen rougher times, and not by her. :)
/ 4X4 engaged on dry pavement #5
If that's it...You're good to go...Forget about it.
/ 4X4 engaged on dry pavement #7
Nope, not a big deal. it happens. Other than some tire wear (so little you wont tell) I doubt it will even phase it in the least
Hey guys thanks for the help!
/ 4X4 engaged on dry pavement #9
the rtv has a limited slip front end and if i'm not mistakin it also has a rearend unlocker right? if so your good to go the rear end being locked is whats gonna really kill them front tires. now if your front had a diferential lock on it then you would have some tire problems.
/ 4X4 engaged on dry pavement #10
our old ('99) yamaha kodiak is full time 4wd, its really hard to drive on pavement and shows more wear on front tires even though we try to keep it on soft surfaces.
/ 4X4 engaged on dry pavement #11
You canb run that Kubota in 4wd all the time and it's not an issue. It will turn less sharp and wear the tires a little quicker but mechanically will not be an issue. Most ATV's and SxS's (Yamaha Rhino, Polaris Rzr, etc) are the same way but have more issue due to the locked rear end.
/ 4X4 engaged on dry pavement #12
We use RTV's at work to plow snow. Most of the time during the winter is spent in 4x4 on pavement. There have been no problems yet with the 900's having 2200+ hours and the 1100 only has 100 or so hours.
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59912)
2019 CHEVROLET...
Headsight Autopilot Kit for Claas (A63117)
Headsight...
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
2021 Bobcat UV34 4x4 Utility Cart (A61572)
2021 Bobcat UV34...
