Still cant get end cap off
/ Still cant get end cap off #1
jeff408
Randle WA
JD 4300
/ Still cant get end cap off #2
Why start a new thread?
Sorry. I wasnt sure what to do. I thought it might be easier to start over.
/ Still cant get end cap off #4
Hello
I believe there is a wire that you will have to remove to get the cap off.
It can be a PITA to get it out.
You may have to find something to push it out.
The ones that I have removed had a tail sticking out that you could use vice grips to hold onto.
Hope this helps
/ Still cant get end cap off #5
There is a retianing wire...You have the older style cylinders. You need to turn the cap till you see the end of the wire, then get a pick under the wire as you turn the cap to start the wire out of the hole. Search the term "wire" in the hydraulics forum.
/ Still cant get end cap off #6
Keeping in the same thread for discussion and future searching so others can learn from your experience is really helpful. And linking to a previous thread is helpful too.
http://www.tractorbynet.com/forums/parts-repairs/162855-cylinder-end-cap-removal.html
Saves a lot of search time looking up your previous posts that had the earlier discussion.
Making a Subject line specific to the problem also helps (as you may have noticed when doing a search :) )
The threads(s) have helped me to understand the inner workings of the cylinders on my 430 FEL on my 4300. So far they are holding up well.
Thanks again guys. I see the wire your talking about. I'll give it a try when I get a chance and report back. Now I can see the value of keeping it all in one thread. I'll do better next time.
/ Still cant get end cap off #8
Yeah...remember I told you there where two different types?-you never gave me an answer to what you had.
/ Still cant get end cap off #9
Anytime you can post a picture of something like that it helps a ton! With a couple good pics, a lot of us here could have told you exactly how to disassemble it.
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
UNUSED RAYTREE RABC44 - 44" ARTICULATING CUTTER (A62131)
UNUSED RAYTREE...
2020 John Deere 1795 Planter (A63109)
2020 John Deere...
CAT CB34 (A60462)
CAT CB34 (A60462)
2019 COLEMAN BT200X MINI-BIKE (A62130)
2019 COLEMAN...
