3-Point Hitch JD 2305 3pt
/ JD 2305 3pt #1
WV 2305
Just have a little over 50 hours on my 2305 and was using the FEL and 3pt box blade to push out briar patches. Was working a little over 2 hours when I back bladed a patch and tried to raise my rear blade and it would not move. Checked the position control knob and all else according to books, nothing works. Any Ideas what may have happened?
/ JD 2305 3pt
Well now, feel a little incompetant but found that the quick coupler on the rear hydraulics had come disconnected but not enought that the hose end actually fell down and looked out of place. Locked coupler fitting and have 3 point hydraulics now.
Thanks,
/ JD 2305 3pt #4
Welcome to TBN:D
Don't feel bad, you would be surprised how often loose quick coulplers cause problems!
/ JD 2305 3pt #6
I think he is refering to the PowerBeyond connection.
/ JD 2305 3pt #9
I had something simial happen to my2305 today. Last week put power beyond kit on and used logsplitter I built for it this weekend this morning for about an hour. Tonight it snowed so I pushed snow with the blade for about an hour then parked it in garage when done, lowered the ballast box on rear then went to lift back up because I was on a cord, but it would not lift, looked into the rate of drop knob but that was not it. Pretty sure no couplers are loose cause just put them on. Any more ideas????????????
/ JD 2305 3pt #10
Welcome to TBN:D
What does "Pretty sure no couplers are loose" mean? Unhook them and re-seat them to be sure. This is the most common "my xyz won't lift anymore" answer.
PREVIEW DATES AND TIMES (A65563)
PREVIEW DATES AND...
2005 Butler pole trailer (A62679)
2005 Butler pole...
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
