Bought a 5525 Today!!
/ Bought a 5525 Today!! #1
scsims
Central, KY
Mahindra 5525
Well I went ahead a got a 5525 today. It was everything that I was looking for and much more.....
Did I make a good choice.
/ Bought a 5525 Today!! #2
Congratulations on your new toy. We must have pictures or you will be beat with a wet noodle:D
Will do, it will be delivered in the morning and I will add some pics!!
/ Bought a 5525 Today!! #4
Congrats. I bought mine in March08. A strong machine. Got the ML250 FEL and a 6-ft Hawkline brush hog. Neglected to get the skid steer quick attach on the FEL so I had to have that installed a few months after the tractor was delivered. Also had my dealer (Daves Tractor) install triple hydraulic remotes and weld bucket hooks (I supplied the hooks, Dave did the welding).
Enjoy your new tractor.
/ Bought a 5525 Today!! #5
Congrats. If I was to get another tractor I would probably get a 5525, but so far my 3215 has been able to do everything I have needed. Enjoy!!
/ Bought a 5525 Today!! #6
Hey Flusher, where did they weld the hooks at? i want to add hooks to mind, just wondering if there is a place not to put them and a place only to put them. thanks
/ Bought a 5525 Today!! #7
On our ML266 had hooks welded on each end - side of bucket adds strength. Any where else on the top lip you have nothing below it to take the stress of the load on the hooks.
/ Bought a 5525 Today!! #8
I thought about the sides, but was afaid the hooks might hang up on things, you are right about the strenght part on the sides. thanks
/ Bought a 5525 Today!! #9
Like this:
Two grab hooks on the outside, one anchor hook in the middle. There's a 1/4" thick stiffener welded to the bucket then the hooks are welded to that stiffener. I bought the hooks at AW Direct
Gunnebo-Johnson Grade 80 Weld-On Anchor Hook w/ 4,400 lb. WLL - 3-3/4"H x 5"L - Mfg# 589357
I also had the Mahindra skid steer quick attach hardware added to the FEL (~$1K).
That QA is real handy--for example for the hay bale squeeze I built earlier this year
Finally, I had triple hydraulic remotes installed by the dealer ($750)
/ Bought a 5525 Today!! #10
Flusher - are the fenders steel on a 5525? Also, what size is the rear tire?
Thanks,
/ Bought a 5525 Today!! #11
Thanks,
Yep, real sheet steel. Only plastic on this baby is on the seat, steering wheel, instrument cluster and the lenses in the lights.
Front tire: 6 x 16
Rear tire: 12.4 x 28
/ Bought a 5525 Today!! #12
Thanks for the info Flusher.
/ Bought a 5525 Today!! #13
Very interested in your set up. Do you have any pics/movies of your bale sqeeze in action? Very curious on that build!:D
/ Bought a 5525 Today!! #14
Not yet. I'll be baling my oat hay in May and I'll get photos then.
/ Bought a 5525 Today!! #15
Front tire: 6 x 16
Flusher,:)
You got a plastic seat on that "little":D tractor?
hugs, Brandi
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
Rotary Brush Cutter Tractor Attachment (A61572)
Rotary Brush...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
