Help! Mighty Mouse Nibbled Kryptonite Maybe
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #1
SPYDERLK
Super Star Member
VA
JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
My BX1500 has a serious problem. Everything on the tractor is working perfectly except the transmission. Im running SUDT and the level is right - fluid clear and clean. Never a problem until yesterday when I noticed that pushing the go pedal for reverse in hi range caused the tractor to shudder. Forward fine - lo range fine both directions. Went ahead and got a good start on snowthrowing. Finished today and its getting worse. You have to really nurse the go pedal to get it to climb a hill or push - even in lo range. Once the tractor encounters a bit of real resistance the go pedal will just drop to the floor as if it lost its servo connection to the transmission and the tractor loses all thrust - it seems to be out of gear. If you let up and re press the pedal it has firmed back up and if you nurse it by pushing gently you may be able get enuf thrust to crawl out of the situation. Reverse is worse - the tractor wont back up much of an incline.
Does anybody know where to look for this problem? Iv heard of something called the charge pump that I think is necessary to supply the servo link to the variable volume hydrostatic pump. Is that correct? Why would it suddenly take a walk?
Ill get to looking for the obvious in a few minutes when the caked snow melts off. Boy I hope this is accessible from external. :confused::)
Thanks,
larry
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #2
Sorry to hear it. I don't know much about your tractor. Mine is a BX2200, and if they are alike:
If any of the hydraulics works, the charge pump must work. If the power steering works, then the flow priority valve is working. If the PTO works, you have fluid to that point, leaving the only thing between the charge pump fluid and the final destination: the PTO relief valve, and the FILTER. I would replace the filter if you have not already, since the filter is the last thing before fluid enters the axial piston pump / motor housing.
After that, I would start to wonder if some sort of contamination was interfering with the three relief valves in the hydro set.
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #3
Thanks,
larry
Larry,
I would check the linkage between the foot pedal and the transmission. Look especially close and the connection on transmission. From what I can see in the parts list it has a pin that hold the linkage onto the input shaft of the tranny. This is the only simple and external common component I can think off that would give the symptoms you are describing.
Typically stuck relief valves should only effect travel in one direction.
Did you notice and excessive or change in noises coming from the tranny. I.e whistling like water fluid escaping under pressure?
Does the tranny get hotter than normal or get hot quicker in one area.
Good luck
Roy
Thank yous for the rational and reasoned responses. The transmission does not get hot at all. Its doing almost no work and the temp is below freezing... No noises either except associated with the shudder when right on the verge of the malfunction and the power stops and starts repeatedly causing a chatter sorta. The filter is making a lot of sense because the malady is less sensitive to elicit when 1st started after sitting awhile and develops as the tractor runs. Almost as if the filter pleating is closing up under sustained flow. I noticed further, that if I lift the 3PH while backing it is worse. Ill be off to the tractor store and report back later.
larry
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #5
Perhaps there is water crystals in the fluid blocking the filter, or the viscosity of the fluid is high enough to cause trouble passing through the filter media.
As for the number of relief valves, my manual shows that there are three associated with the pump/motor set alone, and more than that throughout the system. One for forward direction, one for reverse direction, and one for the ultimate dump of charge fluid back to tank. I may have misinterpreted this somehow, however.
It is hard to keep from worrying about it, I am sure, but I would not become too worried until the tractor exhibited the behaviour with a fresh filter, and warm hydraulic oil. We all see a rash of problems on TBN during very cold weather.
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #6
I'm bettin' Roy (oldnslo) is right about the connection at the tranny. Sounds like a pin missing.
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #7
Afetr 1500 hours, 1 of my 2 L48s experienced real "slowness" (more than the known HST slowness) which I traced back to the pin and worn bracket to the HST pedal. Night and day now, and I would try the linkage as noted.
OK. A brand new filter helps but doesnt cure. I ran it around in hi range a good bit. Another thing I noticed is letting off completely on the pedal for "braking" going down hill can send it into a freewheeling mode - hydraulic coupling is lost. I can see this being very dangerous under the wrong circumstances -- but a clue just the same. When the pedal goes dead [no control] the pto clutch remains engaged -- and the 3ph lift operates normally. In fact, it almost seems the operation of the 3ph lift actually resets the pedal in that case so it works again. Also, problems seem to be worse at full throttle than reduced throttle. .........Any more ideas?? I wonder if this is going to go away when the weather warms. :):confused::)
larry
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #9
From the BX23 WSM, should be applicable to the BX1500 HST.
Good luck.
Dave
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #10
Sounds like maybe the charge pump is on the way out.
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #11
larry
If you run the HST much starving it of sufficient fluid you will damage the the HST I would change the fluid and use SUDT if you have not already. Did you clean the suction screen? I have the WSM and I will check it later to day.
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #12
Volfandt posted the chart that tells the tale.
You said you ran it in high a good bit, but you didn't say whether you were gaining in temperature enough to be sure that if water crystals were present that they would melt. If water were in the fluid, melting it is not necessarily sufficient to cure problems, however, since emulsified water in oil has trouble sometimes going through filter media.
The screen being clean is an important point, but adequate lift movement ought to give a reasonable indication of whether or not that is a big enough problem to account for the symptoms. Nevertheless, I would examine that before I did anything intrusive, or expensive. I have wondered if cavitation in the presense of water might result in vapor, which would not effect hydraulic actuators substatially, but may cause problems in the hydro set.
My instincts tell me to get the tractor warm by any possible means, check the pedal linkages as others have suggested, and then work through the flow chart Volfandt provided, testing at each stage. That may be beyond your capabilities. It is beyond mine, since I don't know where the test points are, and I may not have the fittings. My tractor seems to use some G1/4 testpoints which are BSPP 1/4.
I did see these available from one of the TBN sponsors.
I know it is easy to say, and harder to do, but I believe the above is a logical approach.
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #13
I noticed my BX1500 had quit a bit of moisture in the oil when I did the Service this fall.
You can do what is called a crackle test to see if there is moisture in the HST fluid.
Get a hot plate (or an old Iron ) and warm it up till water rapidly vaporizes when you put a drop of water on it. Then drip a drop of your HST fluid onto the plate and if it crackles it has moisture. To give you a comparison do the same crackle test with new fluid and compare the sounds. Its a quick and easy way to check for the presence of moisture.
The oil can absorb and hold moisture and still lubricate but it will only hold so much and function correctly.
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #14
Interesting tidbit! ;)
Maybe for OP it's time to change fluid and filter again? clean out the HST screen? all of these is easily done by OP.
I admit I have no idea how to check the charge pump on the BX, does anyone know ? This sounds like something we all may need to know for 5-10 years from now ?
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #15
I believe the main pump that lifts the lift arms and drives the power steering is the charge pump.
The priority flow valve grabs a portion for the power steering, pto clutch, and charge function. Someone please tell if I am wrong about this.
There are various relief valves along that path that keep the pressure to the appropriate value for each purpose.
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #16
This is probably a long shot, but do you have fuild filled tires? I read a thread a while back where somebody said they lost power any time they hit resistance.. Turned out the tires were slipping on the wheels.
Have you tried it in 4wd?
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #17
Good suggestion on the tires spinning on the rims. Been seeing this more frequently lately.
Another chart that may prove helpful.
/ Help! Mighty Mouse Nibbled Kryptonite Maybe #18
SPYDERLK
These PDF flies may help if you are going to test the HST and they contain the test points and pressures. If you need any more info let me know.
  • BX 1500 HYDRAULIC FILES HST.pdf
  • BX1500 HYDRAULIC FILES 3 PH.pdf
I will definitely do everything you say before I go into it. It is still functional, just suddenly not right after always being right. It is hard to believe this could be caused by wear so suddenly. Its only been 100 or so hrs since the changeover to SUDT, filter change and screen cleaning. The fluid looks perfect - like when I 1st poured it in. The trans is getting up to luke warm so no frozen water. Not likely any water in so clear a fluid either. Im thinking something is sticking because of the cold. Ill keep using it for the snowthrowing -no choice really- and just baby the travel/push mode. Every thing else works perfect and its running strong.
When/if the time comes Ill have no problem making the measurements. I just need to know where and what I should see under what conditions.
Does anybody know if the suction screen is just a prefilter in the same line as the hydro filter canister. If so its just a restrictive bird catcher with no more birds to catch at this point. Removing it would ease the suction and the finepore high filter area in the canister would keep the oil just as clean. I removed the one in the Mahindra at suggestion of the tech rep. He said they only serve during break in then just get in the way.
Thanks for all the helpful stuff everybody. :)
larry
Thanks Randall! Ill check those out tomorrow.
larry
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
TARTER 180 CATTLE SWEEP (A64277)
TARTER 180 CATTLE...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
