buying a used L3940
/ buying a used L3940 #11
You are going to love this machine. I have my L3940 for 2 years now it does all I ask it to do and more. I have loaded R-4s but still need the box blade when using the loader for rear weight. I have had no problems with mine. The only negative is no traction on ice, getting chains to fix that. Enjoy post pics. when you get your tractor.
/ buying a used L3940 #12
I bought a new L3940 HST, LA724FEL, wr long 60" grapple and BH90A backhoe a month ago. No regrets. Everything works like a charm. The FEL quick attach is wonderful. Quick. Easy. congratulations on your decision. be safe. have fun! :)
/ buying a used L3940 #13
See, this is where I have always differed from 99% of the folks here. I always ask, well actually I don't really ask, I just do it but I always want waaay more than than the tractor can do. I want that 3 foot diameter stump ripped out in a single blow or two or 20, I want those 5000 lb I beams lifted, that 2000 lb rock ripped from its foundation. Am I asking to much or are you guys just to easily satisfied?
/ buying a used L3940 #14
You don't want a tractor. You want a D9 Cat dozer.:)
/ buying a used L3940 #15
John, I'd rather say RaT has a closer to perfect sized tractor or a little undersized tractor for him compared to EMS503 who obviously has more tractor than he needs.
I'm just like RaT. I went from a B2910 (30hp) to an L4400 (44hp) and within the first ten hours had overtaxed it several times. Many times with the B2910 I had it hitched to some immoveable object that required the front tires to be clawing in the air a couple feet off the ground. Same thing with the L4400.
There are a LOT of tractors on this forum that would be great purchases as used units from the original owners who've never used half their potential. If you've not attempted a task that your tractor couldn't do you fit nicely in this category.
I bought my B2910 used with 320hrs w/60"mmm for $9900. It didn't have a single scratch. The tires were perfect. It was regularly washed and waxed and had never been parked outside. Had never used the 3pt or PTO. Man I miss that little tractor!!! I worked the pants off it. :)
/ buying a used L3940 #16
The question is, did you talk to your talk tractor, did you ask things of it to perform? If so, did it respond back? We want to know!
/ buying a used L3940 #17
As my Dad would have said, I treat my tractor like a "Rented Mule". Yes, I definitely talk to my tractors. It's not in the form of a question though. Sometimes it's not printable..... :)
Tractor was delivered today. I need to go to tractor school. Figured that using the tractor, I did in about three hours what I could have done with a wheelbarrow in 30 minutes. The ground was muddy/snowy, it was cold, just a bad day to learn to use a grapple.
I had a hard time positioning the grapple to slide underneath tree limbs, I was either digging up dirt or getting on top of them, just crushing them into lots of little pieces. I'll learn, think I was spoiled watching these videos, it seemed idiot proof, it's not.
Another puzzle, I thought since it had HST, I'd just push the pedal and go. There seem to be lots of different ways to control the speed....gears, throttle, pedal. I was especially wondering about the throttle lever on the right side of the steering wheel, that thing can be set from next-to-nothing to really high rpm, what determines where I put it?
I'm poor-mouthing this but really did enjoy it, still. I know it will just take some time. I really liked the performance of the tractor, just not my performance on the tractor.
/ buying a used L3940 #19
I am very familiar with HST, it took me about 3 1/2 hours to understand HST plus. I really enjoy now! It works beautifully. The grapple requires a hard right hand to the joy stick, quite hard compared to the joystick on the L3830!
/ buying a used L3940 #20
Go to the Kubota website and order a copy of the Grand L series brochure. There is a double pull out section showing in detail the many functions of the HST Plus and where to use them. Also, go to the Kubota website and navigate to the Grand L series page. There is a great animation showing the features of the HST plus and where to use them. For PTO work like mowing, I do not use the auto throttle feature, just pedal control and cruise control. For loader/scoop and blade work, I set the throttle at minimum speed, engage the auto throttle feature, and let the foot pedal control engine speed and tractor speed. I rarely use the HDS feature once I get to work, but you may find it handy (or more confusing right now). Get some more seat time, you will get it and love it. Philip.
Coats 5040A Tire Changer Machine (A59230)
Coats 5040A Tire...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2014 Dodge Journey Van (A59231)
2014 Dodge Journey...
2017 Jeep Patriot 4x4 SUV (A59231)
2017 Jeep Patriot...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
TEREX RL4 LIGHT PLANT (A60736)
TEREX RL4 LIGHT...
